Laminating Ink Jet Prints
2004-02-11 by ms.photolists
I asked a couple of days ago about peoples experiences of laminating ink jet
prints.  Unfortunately I didn't get too many replies.  So I have been trying
a couple of experiments, which unfortunately have not been very promising!
The pictures I am working with are B/O prints on Epson Archival Matte Paper.
Today I tried a Rexel LM50 Laminator (mid range-hot).  Unfortunately where
there is a lot of ink (black areas) it appears that the laminate does not
stick to the paper and small bubbles form.
I have been asked for two copies of an exhibition (60 prints) but because of
the venues I can not screw frames to the walls so I am beginning to panic!
Any experiences or alternative methods of showing prints would be much
appreciated.
Thanks.
Martin
www.strike84.co.uk
Re: Laminating Ink Jet Prints
2004-02-11 by flyfishingusa2002
Why not mount under a thin perspex glass (plexiglass)
Another way would be to seal the print with a coating that you can
get from a signmakers supplier. You might also try to coat the print
with one of the varnish's intended to preserve a matt print.
I would first mount  the print onto a foam board and then try one of
the above.
Sierra Gold
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ms.photolists"
laminating ink jet
been trying
promising!
Matte Paper.
Unfortunately where
does not
because of
panic!
much
> appreciated.
> Thanks.
> Martin
> www.strike84.co.uk
[Digital BW] Re: Laminating Ink Jet Prints
2004-02-11 by don.swanson
I have had no problem with hot laminations using a USI 13" laminator. You do
have to be sure that the prints are dry! Wait a few days before lamination
or heat the prints in a dry mounting press. I have successfully laminated
B&W & Color ink jet prints, Fuji & Kodak prints color prints, color laser
and copier prints. I have some laminated Epson 800 color prints that are
over 10 years old and show no sign of fading.
If you want to go with cold laminators I know of 2 choices I saw at the
Professional Photographers of California show in Pasadena.
The best, and most expensive is:
Pacific Studio Supplies
#170-5640 Hollybridge Way
Richmond, BC. V7C 4N3
Canada
They have a nice Laminating Film Sample that shows 8 textures.
Tel: (604) 278-7937, Fax - 278-7967. Email: pss1@...
The second one is:
Albums Unlimited
1080 Martin Ave.
Santa Clara, CA. 95050
Tel: (408)982-9294
Cold Laminator, 101CL - 13", 201CLA - 25"
Four films - Soft, Clear, Canvas, Linen and Leather.
www.albumsunlimited.com
Hope this helps!
Don
Sent: Wednesday, February 11, 2004 11:26 AM
Subject: [Digital BW] Laminating Ink Jet Prints
appreciated.
Thanks.
Martin
www.strike84.co.uk
they are often being updated.
Re: [Digital BW] Laminating Ink Jet Prints
2004-02-12 by Carolyn Frayn
On 11-Feb-04, at 12:26 PM, ms.photolists wrote:
> snip:
> Paper.
> where
> not
The only semi success I've had with laminants over EEM pig prints, is
by stacking the prints between plain paper and allowing them to cure
for two days prior to the lamination process. They may still have some
mottled areas in denser black zones, but it's greatly improved. The
only great lamination I have achieved is on coated gloss or semi gloss
stock, inkjet or press.  I would not personally show fine art prints
laminated, this is strictly for images designed for commercial cover
art.
Carolyn
