2004-02-12 by Peter A. Klein
Thanks, Paul and Bob.
Judging from Bob's remark, it sounds like it may not be worth it. I
do remember using 2880 with the glossy paper samples that came with
the printer, and not noticing much difference apart from it taking an
eternity to print a humble color 4x6. Anyway, I'll try it with a
small print and see if the difference is worth the time.
The object of all this is to get the dots a little smaller. At 1440
dpi, I can just seem them, and some would find this objectionable.
The dots actually improve some things, like a digital camera
snowscape I printed this week. But sometimes they make grainy Tri-X
pictures look even grainier. It almost seems like the kind of grain
aliasing you get when you scan grainy B&W at 2700 dpi.
I'm hoping that smaller dots might get the grain/print dot ratio off
the "sour spot," just as a 4000 dpi scanner did for
--Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels"
<bob@b...> wrote:
> Specify Photo Paper then use EEM anyway to get 2880 dpi. Then get a
> good loupe to be able to see the small difference. You'll also
> discover a new meaning to the term "long print times".
> Bob Michaels
Paul DeRocco wrote:
>You can lie to the driver about the kind of paper. You'll have to
>print a
>step wedge to see if you get a reasonable gray scale, however. My
>guess is
>that in BO mode, at most you'll need to tweak the ink limit control.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter A.
Klein"
> <pklein@2...> wrote:
> > My 1280 driver (Windows)does not seem to allow the use of 2880
dpi
> > except with glossy papers. When using the Epson Matte Heavy
setting,
> > 2880 dpi isn't even available. That doesn't bother me when
printing
> > color or hextone. But I would think using 2880 dpi would give
> > smaller dots when printing "black only."
> > Is there a way to make the driver print at 2880 with matte
paper?
> > And is it worth it? When printing "black only," can you get
smaller
> > dots at 2880 dpi than at 1440? Or does the matte paper surface
> > negate any advantage of the higher resolution?
> > I'm currently printing B&W with the Ultratone (1) inks, using
Paul's
> > curves for the 1280. But sometimes I like the look of a B/O
print.
> > B/O also helps keep me sane when I can't get the hextone to look
just
> > right.
> > Thanks,
> > --Peter
