Negative Size ?
Negative Size ?
2004-02-12 by randyrancier
I used to be primarily a large format photographer 4x5 & 5x7, as
well as doing a fair amount of 35mm B&W. I worked in silver and
palladium print making. I am fairly new to digital photography and
up to this point have only worked with digital images from my 3
megapixel camera; I've really enjoyed it, and it has gotten me back
into photography.  The digital darkroom is much more convienient
than a wet darkroom, hallelujah!
In the near future I am going to get a wide format Epson printer so
I can do B&W right, with the new B&W pigment inks.  From what I have
been able to gather from various sources on the web for ultimate
control and quality the way to go is using a film camera and then
scanning the negatives.  Not desiring to pull out my old 5x7, or
purchasing a scanner that handle it.  I will be looking at some
second hand medium format equipment, probably
Mamiya.  I really like the size and convienience of the 6x4.5 size
cameras, but I haven't ruled out the possiblity of the 6x7 format.
My question is will I see much of a difference in quality in 16x20
size prints, between the 6x4.5 and the 6x7 format???  I plan on
doing color as well as B&W prints.  I will probably use high
resolution color negative films and the new higher speed B&W
negative films that are color processed.  I may have to resort to
processing my own higher speed B&W negatives if I can't control the
highlights, with the other films mentioned, in my outdoor night
photography.  I apologize for the length of this message!
Thanks to those who respond.
Randy
Re: Negative Size ?
2004-02-12 by Clayton Jones
Hello Randy,
Absolutely, yes.
Clayton
Re: Negative Size ?
2004-02-12 by Scott Graham
I'm thinking of going from 6x6 to 6x7 myself.  and wish there was an affordable 4x5 film
scanner (no NOT a flat bed)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote:
> Hello Randy,
> Absolutely, yes.
> Regards,
> Clayton
Re: Negative Size ?
2004-02-13 by Bob Michaels
Anyone wanting to see first hand what impact negative size has on the
final print should go the Library of Congress web site and download
the 12mb TIF of Walker Evans' "Floyd Burroughs, Cotton Sharecropper,
Hale County Alabama"
http://memory.loc.gov/cgi-bin/query/I?fsaall:43:./temp/~ammem_27kv::displayType=1:m856sd=ppmsc:m856sf=00244:@@@
and then print it. Don't do any PS adjustments other than normal
printer profile, just send the raw 400 dpi 8x10 to the printer. Look
at the print and think about it coming from a 12 meg file but being
from an 8x10 neg.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "randyrancier"
> Randy
Re: Negative Size ?
2004-02-13 by Steven Karafyllakis
so
Having just set up my second 'wide' printer, (Epson 7600) I have to
ask: what do you consider wide format? ie what will be your max size?
 The larger neg size will definitely show in your finished work, but
obviously it will be much greater at 24x30 vs 13x17. As for 5x7:
it's a bear, but that big a neg will produce excellent results on a
$1000.00 flat-bed, wereas the med format negs will require a more
expensive scanner.
The Mamiya 6x7 would be an excellent choice.
> photography.
One nice thing about a good scanner: it is capable of recording a
much wider range than photo paper, and if that's not enough, then
there's all the various editing tecniques to bring it all into line.
Enjoy!
Steve Karafyllakis
http://www.stevekphoto.com
Re: [Digital BW] Negative Size ?
2004-02-13 by KevinG
Randy-
It is a difficult and subjective question to answer.  I think the best
answer is: if you could tell the difference between images taken on
your 4x5 vs your 5x7 then your aesthetic may be bothered by difference
between 6x4.5 and 6x7.  For most people, even very precise people like
those on this list, I suspect that the difference between medium format
sizes would be unnoticed.  The lenses, obviously, make a much larger
contribution.
KevinG
Re: [Digital BW] Negative Size ? Revisited
2004-02-13 by randyrancier
No kidding about the responses.  All I want to be able to do is get
really nice, up to 16x20 prints, color and B&W; most of my work will
be 11x14 or smaller.  I'm not expecting contact print quality, but I
do have a critical eye for sharpness and grain.  I don't think
sharpness will be a problem with either the 6x4.5 or 6x7 neg size,
but at what point will grain become perceptable with the new
negative materials and the tools available with Photoshop?  I'm sure
it depends to some degree on the film used and possibly choice of
scanner.
Thanks again,
Randy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, J Vee
<j.vee@g...> wrote:
> Just one end of the spectrum of responses I expect you will get.
I have
> kind of gone down the road you are exploring.  Found digital
cameras great
> for certain things but not for fine arts photography (?yet).
Settled on the
> 3/4 gig file from (my) drum scanner from 4X5 and 1 3/4 gig file
from 11 X
> 14.  Just no substitute for the look and ³feel² of the work from
this
> source, no matter what I do in Photoshop.  This is true even with
a print as
> small as 11 X 14, of course even more so with a 48 X 65 mural
print.
and
back
2004-02-13 by Mark Hahn
I would consider your camera options first.  With different
film/developer combinations you can probably make up most of the
difference, or at least get what you want out of either, and as
someone said, the lens will play in big time.  But you have to live
with your camera choice for all the photos you take.  If you fall in
love with one of the 645 cameras you will be able to make it work for
you, if you fall in love with a 6x7 then get that.  Going 6x6 puts
you in the middle and also gets you out of having to flip the camera
for portrait or landscape format if you allow cropping... not all
medium format cameras shoot *that* comfortably in portrait mode).  If
you don't care, then just assume bigger is better.
mark
will
I
sure
> scanner.
> Thanks again,
> Randy
> I have
> cameras great
> Settled on the
> from 11 X
> this
> a print as
> print.
> and
> back
2004-02-13 by Tom Baker
Many people are doing really good work in the 645 format.  The smaller formats leave no room for error in exposure, development, etc.  While film/developer combinations play a role in the final product, good technique and attention to detail are absolutely critical to excellent, consistent results in smaller formats.
Tom Baker
scanner.
Thanks again,
Randy
I have
cameras great
Settled on the
from 11 X
> 14.  Just no substitute for the look and �feel� of the work from
this
a print as
print.
and
back
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
   To visit your group on the web, go to:
2004-02-13 by J Vee
Just one end of the spectrum of responses I expect you will get.  I have
kind of gone down the road you are exploring.  Found digital cameras great
for certain things but not for fine arts photography (?yet).  Settled on the
3/4 gig file from (my) drum scanner from 4X5 and 1 3/4 gig file from 11 X
14.  Just no substitute for the look and ³feel² of the work from this
source, no matter what I do in Photoshop.  This is true even with a print as
small as 11 X 14, of course even more so with a 48 X 65 mural print.
2004-02-14 by randyrancier
I think what I will probably end up doing, since I will have to sink
a considerable amount into a decent scanner that will handle 2 1/4,
I will get a older TLR camera with a good lens and see what I get.
A 6x6 image cropped will use approximately a 6x4.5 of the negative.
If I'm happy with the results then I can move on to 6x4.5, otherwise
it will be a 6x7.  Who knows, by then maybe the digital cameras will
have the edge.
Thanks for all of  your responses; it's always good to hash things
out before jumping.
Randy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker
> Tom Baker
get
will
I
sure
> scanner.
> Thanks again,
> Randy
get.
> I have
> cameras great
> Settled on the
> from 11 X
> this
with
> a print as
> print.
as
> and
> back
convienient
to keep them short.
group Owner and Moderators. See "Group Topic, Rules and Guidelines"
THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF
Service.
2004-02-14 by D. Hill
This is interesting - as I am going through the same
process.
I had been using an Epson 3200 for all my negative
scanning, then I purchased a Canon 10d.  With my
printing sizes, shooting 35mm is no longer needed.
The 35mm scans from the 3200 just can't hold
themselves up against the 10d.  Plus the obvious
benefits of not needing to dust-clone and all the
money I am saving by not buying compressed air.
As the 35mm negatives were just too soft when scanned
- I mothballed the scanner.  I have been contemplating
a new dedicated film scanner purcase, but I've bought
enough (know what I mean?).  Besides, as I print
smaller than 11x14, I do not need to shoot 35.
The moral of the story, yesterday I scanned a 645
negative with the 3200.  I had run a few tests and
found that no matter how I scanned it - Full
resolution via the epson driver, or at the output size
at 360dpi with silverfast with 4 passes; I get the
same sharpness (but vastly different file sizes).  So,
I scanned a negative directly with silverfast at an
output of 4x5 with 360 dpi, and printed the image
directly without any photoshop controls or
intervention via UT2/1280.  I can honestly say that
this is everybit as sharp as a contact print - and the
ink gives a certain "platinum" look to the final
image.  Once agian, kudos to Paul.
I have not tried a large print from the from the same
scanner, but at the native resolution and a 6x6
negative - I believe you can make around a 20x20 with
360dpi.  I can attest that medium format negatives are
sharp with my 3200.  Pretty good for an inexpensive
flatbed...
Don
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
