awful yellow green tint
2004-02-15 by alanlabb
Hello,
I also posted this question to the Piezography group. I apoligize for the
redundancy but I know this is a bigger group and I am hoping for a quick
solution.
I just loaded up an Epson 7500 with selenium toned piezo ink. I am using
IP5.6. And the ink I am using was purchased in July -I wanted to use up most
of the OEM color ink in the printer since I have access to an Epson 9500 with
the same inkset at my institution. I followed all the updated instructions,
loaded the flush cartridges into the printer yesterday afternoon and loaded the
Piezo ink cartridges today. I pulled each one out for a reset and then
performed an initial load of the ink. My first test print looked good but my
second larger print came out with a terrible yellow-green tint, as has every
print since. I also tried to run the flush image that came with my old CIS
system to no avail.
I think two things could be wrong. When I ran the first flush my yellow cartridge
light began to flash by the end of the cycle. The flush cartridges were bought
this week at IJM and I had to break off tabs to get them to fit into the 7500 -its
possible this cartridge might not have set correctly and therefore not fully
flushed the yellow. Why would the first print look neutral and from neutral
progress to a not so slight yellow/green tint? The only other possibility I can
imagine is contaminated, badly labeled (maybe one or more cartridges are
not really SL), or simply bad ink. I will try and find a CMYK image and run it
with a color profile to identify if one ink is tainting the whole process. Any other
words of wisdom? I do not have an owners manual can you purge one ink
without dumping the rest? Jon is it possible to have a bad batch of ink? Since
I am familiar with the selenium set I know this is not how it usually looks.
Thanks in advance for your help.
Alan Labb
Re: awful yellow green tint
2004-02-16 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "alanlabb"
<alabb@m...> wrote:
Alan; The manuals for that printer can be downloaded from
http://www.nighthawksolutions.com/
As for flushing only one ink, if they allowed us to do that, think
of all the money they'd lose! The only way to flush only one line is
to release the head, take the cover off, remove the plastic bar that
holds down the dampers, and pop the damper/inkline of the nipple.
From there you can put a windex refilled flush cart in, and using a
syringe with an MIS bottom-fill adapter, gently pull through enough
windex to verify that all the color is gone. Replace the ink cart,
pull ink into the damper. If you want to, you can also put a short
piece of plastic tubing on the syringe and flush the head as well. A
good trick to know if you ever get a really intractable clog. Of
course, you want to get some paper towels under the head and ink
lines before you go sqirting messy liquids around. I know this all
sound radical, but it works, and is not very difficult I'm a
cheapskate, this is how I change my inks in my 7500! And I'm about
to figure out how to do it in my 7600 as well..
Best of luck, keep us posted
Steve Karafyllakis
http://www.stevekphoto.com
of ink? Since
usually looks.
> Alan Labb
