Hi again. Bob Zeiss sent the following setup instructions:
"Try
Print Media = Heavy Wt Matte Paper
Print Quality = Best Photo
High Speed = Off
Color Management = Automatic
Sliders = zero
Some papers work better than others. Start with Epson Enhanced Matte."
With the current Mac C84 driver, there is no "Automatic" choice for Color
Management. However, setting Color Management to On with all sliders set to zero
did the trick. The 21 step file prints nicely on EEM.
When MIS says Warm, they mean Warm :-)
Ed
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "edrudolpho"
<erudolph@p...> wrote:
> Thanks very much, Paul! This morning I wrote an email to Robert Zeiss, similar to
> one I posted on the list here. I'll let you know if he replies.
> Ed
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> <paul.roark@v...> wrote:
> > The "EZ" inkset I made was for the C82, not the C84. I have never seen how
> > the C82 inks work in the C84, so I can't really comment. I'll recommend MIS
> > loan me a C84 if they want me to see what is going on and what inkset
> > modifications might be needed for it.
> > Paul
> > www.PaulRoark.com
> > For UT2 information, curves, and settings see:
> > http://home1.gte.net/res09aij/
> > ____________________________________
> > From: edrudolpho [mailto:erudolph@p...]
> > Sent: Thursday, March 04, 2004 12:03 PM
> > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > Subject: Re: [Digital BW] new UT EZ inks for C84 printers
> > Hi all.... in addition to printing on an R800 I've been trying out the UT EZ
> > inks on a
> > C84. As Paul has outlined, there is no procedure to following, really, with
> > this inkset.
> > However, I haven't really gotten satisfactory results yet, using a Mac on OS
> > X.
> > I printed the 21 step file with a Source Space of Gray Gamma 1.8, a Printer
> > Space of
> > Same As Source. Matte Paper - Heavyweight, is the media type and No Color
> > Management is selected.
> > I have tried this with PR 308 and EEM, and also with media types that might
> > conceivably require less ink. On EEM, the 21 step file shows the same
> > density for 85-
> > 85, thought 80 and 100 are distinct from that range.
> > Isn't this supposed to be EZ :-)
> > Ed Rudolph
> > > Ed,
> > > The "EZ" C82/84 inks assume no profiles or anything. That is, they were
> > > aimed at novices who would not do anything to their systems. So, I'd use
> > > "same as source" with a file that has not embedded profile.
> > > The "warm" is un-toned carbon. If you want a tone between neutral and
> > > carbon, you can, for example, stick a warm cart in the yellow position.
> > If
> > > you do this you must use a grayscale file to print from.
> > > The C82 worked best with EEM and PhotoRag because of the good dmax these
> > > papers have. A "problem" with the C82 was that it under-printed the 100%
> > > black with some color inkset. This made for smoother transitions but
> > > lowered the dmax. Whether this is still true with the C84 is unknown.
> > > Someone sent me a dmax reading that may indicate the C84 has a better
> > dmax.
> > > Good luck.
> > > Paul
> > > www.PaulRoark.com
> > > ______________________________________
> > > Sent: Monday, February 23, 2004 7:16 AM
> > > Subject: [Digital BW] new UT EZ inks for C84 printers
> > > Hi all, I've just ordered a set of the EZ B&W UT inks to use with an Epson
> > > C84 printer
> > > that I got for free when I bought a computer recently. Here is the info
> > > from the MIS
> > > website:
> > > "There are 2 inksets for the Epson C82 (&C84) , a warm set (EZW) and a
> > > neutral set
> > > (EZN). Both make beautiful prints with out any workflow whatsoever.
> > This
> > > means
> > > that all you have to do is install the cartridges in the printer and
> > print.
> > > There are no
> > > adjustments required, no curves to fuss with, and any software that can
> > > print an
> > > image can be used. The images can be in color or grayscale, it does not
> > > matter. Of
> > > course you will need some fine art paper and you have to print in the Best
> > > Photo
> > > mode with no color adjustment. It is Easy to make great looking B&W
> > > archival quality
> > > prints. Matte and glossy prints can be created by selecting either an
> > Eboni
> > > black
> > > cartridge, for matte prints, or the Photo Black cartridge for glossy
> > prints.
> > > The
> > > Ultratone CMY cartridges work on both types of media. The inks were
> > > optimized for
> > > Hahnamuhle Photo Rag paper. Other papers may produce different results."
> > > My questions: what Proof Setup, if any, would you use in PS7 or CS?
> > Would
> > > you send
> > > the images to the printer with the Printer Space set to Same As Source?
> > > Thanks for any info
> > > Ed
> > > Please visit the Group Homepage to check the Files, and other resources as
> > > they are often being updated.
> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > > If you wish to receive no emails or just a daily digest, or you wish to
> > > unsubscribe, please edit your Membership preferences by visiting this same
> > > page.
> > > Please follow these basic guidelines:
> > > - As threads develop, trim off excess portions of earlier messages to keep
> > > them short.
> > > - Good manners are required at all time. No personal attacks or flames.
> > > Hostile, aggressive or argumentative users may be removed from the
> > > membership without notice.
> > > - Keep your posts and threads related to the group topic of digital B&W
> > > printing. Users who persistently make off-topic posts may be removed from
> > > the membership.
> > > - By posting on this forum you agree to abide by the group rules and
> > > guidelines, and to abide by the actions and decisions of the group Owner
> > and
> > > Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT
> > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
> AND
> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE
> > TO YOU
> > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> > EXEMPLARY
> > > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> > > GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER"
> AND
> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED
> OF
> > THE
> > > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
INABILITY
> > > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
ACCESS
> TO
> > OR
> > > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT
> > OF ANY
> > > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
OTHER
> > > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > > Yahoo! Groups Links
> > page.
> > them short.
> > the membership.
> > guidelines, and to abide by the actions and decisions of the group Owner and
PRINT
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE
> TO YOU
> EXEMPLARY
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED
OF
> THE
> > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
> > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS
TO
> OR
> > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT
> OF ANY
> > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> > Yahoo! Groups Links
