Roy,
I think then, that I will do the show on 4/1 (I incorrectly wrote 5/1) with the 2200
and my old workflow.
I am however still interested in experimenting with the 7600 at some point.
Please do drop me a line when you make progress. I do have a
densitometer.
On a side note, I am a bit shocked that the 7600 is not smart enoght to realize
to do a cleaning cycle only on the black print heads when changing from
matte to photo black or vice versa -- a tremendous waste of ink!
Thanks and take care.
-John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington" <
roy@h...> wrote:
> Hi John,
> A two day window is short no matter what the issue, so I'd have a plan B
> anyway. Modifying the 2200 profiles for the 7600 is probably not a
> difficult task but would require a densitometer for the final linearization.
> If your two day window can wait a little while I'm hoping to get some
> profiles done on the 7600. Right now there seems to be a hangup in my
getting
> the inks switched from photo to matte.
> Roy
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chervinsky02144"
> <chervinsky@d...> wrote:
> > Hi Roy,
> > Thanks for the rapid and thoughtful response.
> > Unfortunately, I will have the 7600 set up with matte ink and HPR paper. It
is
> > my hope to make large prints for gallery opening on 5/1. Can you tell me
how
> > involved it is to make a B&W profile if I've never done it before? I suspect
that
> > it is an order of magnitude more difficult with color inks. The main problem
is
> > that I have only a 2 day window to use the printer. It's not the end of the
world
> > if I use smaller prints from my 2200. Should I punt at this point?
> > Best,
> > -John
> > > Hi John,
> > > I've done some initial work with a 7600. The one I'm using has
> > > Photo Black not Matte Black ink loaded. Which kind of black ink
> > > are you using? I can send you a couple of profiles for EEM using
> > > this setup.
> > > Roy
"chervinsky02144"
> > > > Hi,
> > > > I just spent the morning installing Roy Harrington's QuadtoneRIP
software
> > > > and have succesfully been making very nice prints on my Epson 2200
> > with
> > > > the UC inkset. So far, I am very impressed with the software.
> > > > I am, however, just using the 2200 as an exercise. The real purpose
of
> > > > getting the software running is that I will have access to a 7600 printer
> > next
> > > > weekend. Are there any profiles available for the 7600? If not, will I
be
> > able
> > > > to use the software with the 7600 without developing curves? Has
> > anyone,
> > > > for example, tried using the 2200 curves?
> > > > Thanks very much.
> > > > -John Chervinsky
