Yeah, well... even without doing the test I just do the cleanup as
good as possible :)
In other fields I have heard the phrase, "computers haven't made
things easier, they've just raised the bar for what is expected." A
friend of mine has 3 Ansel Adams prints and they are all spotted
quite poorly...
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, hogarth
<hogarth@s...> wrote:
> Yep.
> I've done an experiment to see just how much cleanup to do. Print a
> section from an image as big as you ever think you'll make a print.
For
> me, that was about a 12inch square from what would have been a 40x50
> inch print (from a 4x5 original). Then do your best to clean it up
in
> Photoshop and print the section again. Put the prints side by side
under
> the same lights and see how much difference it makes to you.
> This may help you decide how much work to do. In my case, it made me
> think I should just suck it up and clean up as best I could. You
don't
> have to live with the little imperfections anymore - especially in
clear
> tones like open sky. Barely visible, is still visible.
> The reason to do the test is, YMMV.
> On Sat, 2004-03-27 at 12:43, Mark Hahn wrote:
> > after I went to scanning I was horrified at all the dust and
> > scratches that I had to deal with so out of curiosity I took out
a
> > bunch of old traditionally printed photos that I thought I was
happy
> > with and looked at them under a loupe... guess what? They had
all
> > the same dust and scratches that I saw in my scans... but with
those
> > scans I had only worried about what showed up on the print. The
> > problem with PSing is that it is an instant loupe and you start
> > wanting everything perfect at that level instead of on the print.
> > mark
