1290 printer + 1280 driver + UT2 = success!
2004-03-27 by scrber
Just to let you know, I have now re-installed the driver on one of
my 1290 printers with the US 1280 version.
The prints using UT2 are much better than with the 1290 driver.  I
guess the mechanics of the printers are very similar and just the
software alogithms differ.
Compared to my numerous attempts with VM inks using 1280 and 1290
curves, the UT1 inks and 1280 curves, UT2 inks with 1280 curves - I
am now getting cleaner, bronzing free and smooth prints.
It is a very easy process and I would recommend any of the 1290
users to give it a go (you can switch back to the 1290 driver in the
printer settings at any time...)
Steve
Re: 1290 printer + 1280 driver + UT2 = success!
2004-03-27 by Gareth
Steve, I have being doing some work with Paul on this issue.  I am
going to download the drivers and try some test prints this
afternoon, although I have not had any problems with the prints on my
1290 and UT2.  Then again I have not had anything to compare them to,
other than my UT1 prints!
Cheers
Gareth
Ca--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "scrber"
> Steve
I was also ahppy with the 1290 driver, the ramps I sent to Paul
looked OK except for the dark sepia ones.  I also got bronzing with
Ilford papers, Pauls ramps didn't show this so I KNEW there was a
difference.
Steve Taylor had gone straight for 1280 drivers and was happy.  I
thought that, as they were switchable, I'd try the two back to back
(I've also got several 1290s).  The results are clearly better in
terms of tonality and linearity.  The bronzing is gone and on Ilford
smooth the prints are gobsmacking!
regards
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gareth"
my
to,
> Cheers
> Gareth
of
I
1290
 I
> the
> > Steve
I have done same printing onto EAM using four permutations - NCA,
Colour Adjust-Auto, 1280 and 1290.  The results can be seen at
http://www.imagesoflife.co.uk/full-analysis.jpg
NCA prints on the left, 1280 prints along the top.
I have yet to print some of my own 'real' test images to see how they
come out but looking at the wedges I probably won't have to add the
extra contrast curve I currently do when printing UT2s.
Thanks for the suggestion
Gareth
> difference.
Ilford
> regards
> Steve
am
on
> my
> to,
> > Cheers
> > Gareth
> of
driver.
> I
> the
> 1290
curves -
>  I
in
> > the
> > > Steve
2004-03-29 by colingruk
I suffered - yet another -  crash on my Win2k system (HDD containing
system and program files only)  last week and colleagues got me back
on track.  However loads of files were lost/corrupted.
{As an aside that may be useful to some, I like a print to have wider
margins at the bottom than at the top and so use many custom print
sizes.  I did not know where to find these settings and Epson UK
advised that the "Custom Paper Size File extension … can be
found
under the following path:
D:\Program files\EPSON\EPSON stylus ( printer model )
( Where D is the drive where Windows 2000 is installed )
An example of the file that may be within the folder is
E_DD02JE.UCF. "]
To get to the point!
As no printers were available and all had to be reinstalled,  I
decided to load first one 1290 with UT2 on continuous flow using the
conventional printer port so that I could subsequently load the other
1290, which uses a continuous flow with colour inks, and not get the
printers confused in Win 2k.
The 1280 on 1290 loading process failed to install many of files,
many of which appear to be printer monitor GIF files.  Every time I
switch the printer on it asks for "xxx..dll"'s and the rest,
so I
cancel the operation.  Bit of a pain but the printer works.  Maybe
they are files for the status monitor?
I used Pettit's 100 step wedge (modified so that all adjacent
tones
are adjacent when printed).  They looked good to me although there
are clear steps in two or three places, differing depending on the
curves used.
I did some prints and am very pleased.  For a recent birthday,
colleagues bought me book of photos taken by Edward List (Magnum) in
the thirties of ancient Greek monuments.  They have a lovely burnt
umber/chocolate hue.  I found the dark sepia on EEM too rich for my
taste and just played about.  I have the curves as an action and
found, after a bit of fiddling, that > edit > fade 50% was very close
to what I wanted for one image, and this was even better when done on
Photorag.  I also like the carbon curves, but am experiencing some
roller issues. This may be because of using the printer port, which
is painfully slow.
In conclusion I'm thrilled and eagerly await the promised 1290
curves, Paul, when you have time, or, alternatively, advice on how to
have two 1290 printers operating using USB through the same hub as
before, but one using the 1280 and the other the 1290 printer systems.
Colin
2004-03-29 by scrber
Hi Colin - I don't get this entirely.  I have two 1290 printers
running on one machine, and a third through my home network onto
another machine (all on USB both PCs running XP pro).  I only have
one of these printers using the 1280 driver.  You must not have the
Status Monitor installed.
In the printers advanced setting tab, you can choose the driver for
each printer.  Providing you have both sets of software installed,
this should be switchable.  Did you re-install the 1290 printer
software first and THEN upgrade to the 1280 - if not, this could be
the problem.
Otherwise, try the actual printer settings in control panel, set the
one to use the 1290 driver and the other to use the 1280 driver.
Let me know how you get on.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "colingruk"
containing
back
wider
 can be
> found
> E_DD02JE.UCF. "]
other
> so I
> tones
> curves used.
in
close
on
> is painfully slow.
to
systems.
> Cheers,
> Colin
> the problem.
> Steve
Hi, Steve,
Looks as if I was trying to be too clever by half.  I just thought it
would not be possible to load the colour 1290 with 1290 software
through the same hub and then the UT2 1290 without it automatically
loading the 1290 drivers.  I loasded the UT2 1290 first with the 1280
drivers and then the colour 1290.  I'm looking forward to trying it,
if the dentist doesn't give me too much grief, tonight.
I will first remove the status monitors on both printers and switch
off then disconnect the parallel port lead, reconnect the USB and
switch on the UT2 1290.
If the found new hardware wizard pops and gives me the option, I'll
load the 1280 software, otherwise try to change it in the advanced
tab.
Thanks for your prompt response.
Colin
I would try it the other way around.
If, after your PC crash, you lost the 1290 software.
Re-install your printers as normal, with the 1290 software.
THEN, when all is running OK, add the 1280 driver from the US site.
Then you can switch between it and the 1290 version for either
printer.
Hope it runs OK...
Steve
> Hi, Steve,
it
1280
it,
> tab.
> Colin
> printer.
> Hope it runs OK...
> Steve
All printers were up and running last night, it's just that the UT2
1290 is painfully slow.
Will let you know tomorrow if I had a go at it.
Colin
2004-03-29 by brianmaytum
> printer.
> Hope it runs OK...
Dear Colin,
If you are still not up and running, I have some experience in
running multiple Epsons. I don't think you should have any problems
doing what you want to do.
I work for Epson selling printers in a "Big Box" computer store as
well as merchandising a group of office stores. In the computer
store, they have a demo setup that consists 27 Epsons, HPs and Canons
all hooked to one computer through a maze of USB cables and hubs.
The computer is available to the general public so the opportunities
for operator error and/or malicious actions are substantial. In
addition, the cables are run through the inventory storage space, so
accidental disconnections are common. The result is a regular loss of
printer communications and drivers.
The system runs WinXP pro, which is quite similar to Win2000. If the
mess described above works, your running 2 printers should be simple.
You could use the Parallel port for one of them, but I find USB to be
both faster and more consistent at finding specific hardware. Each
machine has a unique identifier to help the USB/drivers system locate
it so I think it unlikely either would be mistaken for the other.
First, If your OS crash was so bad that it took out OS related
functions like printer drivers, you might want to consider how far
the damage extended and perhaps renew the whole system instead just
dealing with the printer drivers.
Assuming you don't reload, I would start by removing all printer
drivers from the computer using the add/remove programs function. I
would also physically delete all the files in the printer directories
to make sure you get a clean install. If, and ONLY IF you are
comfortable navigating the registry, I would also delete all
references to Epson from the Registry. Obviously if you have Epson
scanners, etc. you will either have to be careful here, or reinstall
their drivers as well.
As far as which to install first, not knowing the details of the
custom driver or how aggressive it is, I am not sure which to do
first. If the custom driver is an add-on to the factory driver,
clearly the factory driver must be loaded first. In that case, I
would install that machine first, then connect the second one and
reinstall the facory drivers for that one.
If they are independent, I would install the one I most wanted to use
last, so if it wrote over both installations, I could still get what
I want right away. Alternatively, I would install the factory drivers
last because they are generally good about respecting previous
installations of the same type of printer.
For example, if some one sells a demo printer that has been
installed, its drivers will not drive an identical replacement
because the serial number is not the same. Therefore you have to
reinstall the driver software.  I have seen as many as 8
installations of the same type of printer. Deleting the unused ones
does not change the functional one. Usually the last one is the one
to keep.
Other issues involve the OS "losing" the printers. This is a USB
issue generally caused by disconnecting and reconnectiong the cables.
A reboot usually fixes that. Swapping cables can cause problems,
especially if done while powered. Powering up the computer with only
one of the printers attached can cause problems for the printer
driver finding the printer. Check the port assignments and correct as
needed.
I hope this is useful. It applies to those of you running multiple
printers of all kinds, mixed or not.
Most of this has been learned on the spot, not through official Epson
technical information, so there may be considerations I have missed.
However, I have been maintaining the system for over a year and most
of the time, all the printers are capable of providing a
demonstration.
It has been a tremendous amount of fun having part of my job consist
of making the most beautiful prints I can from every printer in the
line using supplied ink and paper.  Unfortunately, I am stuck with
the black options of the standard printers, though a stock R800 and
Stylus2200 are not too bad in that department.
bmaytum
2004-03-30 by colingruk
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "brianmaytum"
<bmaytum2000@m...> wrote:
> Dear Colin,
Canons
opportunities
so
of
simple.
be
locate
directories
reinstall
use
what
drivers
> to keep.
cables.
only
as
> needed.
Epson
missed.
most
> demonstration.
consist
> bmaytum
Brian, Steve, Gareth,
Yippee!  UT2 1290 using 1280 drivers is up and running – I'm so
pleased.  I managed to get a lovely, moody print using the carbon
curve last night as well.  Thanks, Steve.
Thank you too, Brian, for your comprehensive advice – I suspect this
will interest many list members.  I have kept a copy of what you have
posted, but which I did not see until this morning at work.  I did
not try the other printers but will do so tonight.  Assuming they are
all working I shall probably leave well alone until the Gods do me
down again. (Is this because I live in Greece and can see Olympus on
a clear day from my lounge!)
From Saturday I'll be on leave in Blighty until after Easter but,
after that, if Paul wants info on where the jumps are in Pettit's
step wedges with my setup, I will try to document and post them, but
I don't have densitometer.  Whether or not these will mater in real
images I don't know but, in some cases, I think I would want to open
up in the 8 or so steps leading up to Dmax.
Awhile back I installed a PCI card with USB 2.  In real life, will
using this enable materially faster printing than using the USB 1.1.
socket to which the printers are currently connected?
Thanks again for all your help.
Colin
