Hi Steve,
I'm not sure what more I can add, but the weird patterns you see are
the way the microweave works. It is strange and the exact gray value
being printed does affect it showing during the lay down. Part of the
reason using QTR shows this more than the Epson driver is that fewer
number of inks are being used. In the cases I've seen when all the
passes are finished the effect is completely covered up. But it sounds
like you are left with some kind of scratch-like banding.
Have you always had the problem? Changed inks recently? Is it
mage dependent? Slightly tonal changes or just adding a small amount
of noise may help.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@=
b...>
wrote:
> Hi Roy
> Sorry I should have said that the scans were taken from images where I
> intentionally ejected the print early so that you can see how the ink is
> being laid down differently in the affected areas vs the other parts of t=
he
> print. Once the head has fully passed over then the difference is not so=
> obvious - just the fine horizontal scratch-like effect. The issue is mor=
e
> obvious when watching the printer lay down the ink. To the left and righ=
t
> of the affected area there are random dots. In the middle it is much mor=
e
> like streaks of ink. In each case this is the leading edge of the print =
> the first inch roughly.
> Thanks
> Steve
> Hi Steve,
> What it looks like to me is the microweave pattern. It this at the end=
of
> the
> image area? I think the problem is that the printer didn't finish printi=
ng
> the
> end of the image. It takes a little while to process the white margin a=
t
> the
> end of a page and the final print data very often doesn't get sent to the=
> printer
> until after the margin is processed. So I'm guessing that maybe you
> manually ejected the print prematurely.
> Roy
> Please visit the Group Homepage to check the Files, and other resources a=
s
> unsubscribe, please edit your Membership preferences by visiting this sam=
e
> page.
> - As threads develop, trim off excess portions of earlier messages to kee=
p
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from=
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner =
and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:=
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE
TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF
THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILIT=
Y
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO=
OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT
OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/SIG=12cfipqga/M=289246.4720081.5892317.2127754/
D=egrou
> pweb/S=1705019182:HM/EXP=1080510151/A=2060596/R=0/SIG=11ion5580/
*http://youc
> ansave.directtrack.com/ad/5108/CD2992>
> * To visit your group on the web, go to:
> * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/
> * To unsubscribe from this group, send an email to:
> * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint-
unsubscribe@yahoogroups.com?subject=Uns
> ubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
