Re: [Digital BW] Re: Epson 1160 Dilemma
2004-03-27 by Phil Morse
However the look really great! Phil Morse
Subject: [Digital BW] Re: Epson 1160 Dilemma I use the 1160 with the MIS VM inkset and while generally pleased, I will be switching soon to the UT1 set. If you go with the VM inkset you should use the curves that Paul Roark created for the 1160 and UT1. They give much smoother results than the original curves. The only drawback of the new curves is that the slider to fine tune the toning control is not available. Andy
