If you have a great greyscale scan, sharpen with PS, if it isn´t a
great greyscale scan, throw it away therefor you do not have to
sharpen it. Look at Unwerth´s photographs! She never knows anything
about photography, but what crazy prints!!!
You know what I mean?
Bernard from Austria
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
<scho@m...> wrote:
> I use PhotoKit sharpner for my digital camera RGB files, but not
for
> the 16 bit grayscale scans of my 4x5 negs. Unfortunately,
Photokit
> Sharpener will only work with RGB files and if I convert my 16 bit
gray
> scans to 16 bit RGB things slow to a crawl when the layers start
piling
> up and file size exceeds 1 gig. I'm currently using Deadman's
custom
> sharpen action (http://www.pinkheadedbug.com/links.html) for the
16 bit
> gray scans so I don't have to convert to RGB and the results are
as
> good as PhotoKit.
> On Tuesday, April 13, 2004, at 02:04 PM, Steve Kale wrote:
> > Broadly consistent with the Photokit guys. Capture sharpening,
> > Creative
> > sharpening (if desired) and then Output Sharpening.
> > From: hogarth <hogarth@s...>
> > Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > Date: Tue, 13 Apr 2004 13:19:56 -0400
> > To: "digitalblackandwhitetheprint@yahoogroups.com"
> > <digitalblackandwhitetheprint@yahoogroups.com>
> > Subject: [Digital BW] Sharpening vs. Print size [was: Image
Density vs.
> > Print Size]
> > Ummm... why not? Worst that can happen is I get flamed as a
heretic.
> > Again. This theory is not supported by house painters, however.
8-(
> > Sharpening should be done in several stages. All scanning
softens the
> > image by definition; scanning lays a deterministic sampling grid
over a
> > stochastic spread of grain clumps. First, you do what I call a
grain
> > sharpening, to restore the sharpness of the image after scanning.
> > Digital output also softens an image. Printing, for instance,
converts
> > square pixels into round-ish blobs of ink. Resampling algorithms
either
> > sort through data and throw some of it away, or sort through
data and
> > manufacture more based on what the algorithms see. This of course
> > softens the image. How much softening depends on how much you
change,
> > and how much you can see.
> > For example, take an image (at 360dpi) and print it at printer
> > resolution 1440, and at 2880 (or any other two printer
resolutions).
> > When you compare the images, the 2880 often looks sharper than
> > 1440.
> > It's not because the data in the file you sent to the printer was
> > sharper; that data didn't change. It's because in one case the
printer
> > used 4 ink dots per pixel, and the other case it used 8 ink dots
per
> > pixel. The 8 ink dots can more accurately reproduce the pixel,
and thus
> > the print appears a bit sharper.
> > To deal with this, here's what I do. Of course, YMMV. First, I
do a
> > light grain sharpening just after scanning (let the cries
of "heresy!"
> > begin). Then, just before output, I do a heavier sharpening
(after I
> > resize for output). If you are doing severe downsampling for web
> > publishing, you'll need to really sharpen the image to get it to
be
> > representative of the image when viewed on a monitor. If I'm
outputting
> > to a printer and printing a smallish image (8x10 say) the
sharpening is
> > lighter. As the size goes up, so does the output sharpening. All
of
> > this
> > just to get the image to "look consistent" across sizes. To my
eye.
> > Unfortunately, I haven't come up with a rule of thumb for
sharpening on
> > either end. On the scanning end, it's going to depend on your
scanner
> > and your enlargement factor, your film, your processing, etc...
On the
> > output end, it's going to depend on your output device, your
> > enlargement
> > factor, the detail in your image, etc....
> > There are those that say that sharpening should be a three step
thing,
> > with a local area sharpening done as part of image manipulation.
I've
> > never seen the need for that with my images. Might be useful for
some
> > though.
> > So.... While I wish that sharpening were a one size fits all
print
> > sizes
> > thing, it doesn't seem to work out that way. I'll say it again:
YMMV.
> > [Non-text portions of this message have been removed]
> > Please visit the Group Homepage to check the Files, and other
> > resources as they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you
wish
> > to unsubscribe, please edit your Membership preferences by
visiting
> > this same page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier
messages to
> > keep them short.
> > - Good manners are required at all time. No personal attacks or
> > flames. Hostile, aggressive or argumentative users may be
removed from
> > the membership without notice.
> > - Keep your posts and threads related to the group topic of
digital
> > B&W printing. Users who persistently make off-topic posts may be
> > removed from the membership.
> > - By posting on this forum you agree to abide by the group rules
and
> > guidelines, and to abide by the actions and decisions of the
group
> > Owner and Moderators. See Group Topic, Rules and Guidelines in
> > Files section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
THE
> > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT
THE OWNER
> > AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT
BE
> > LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED
TO,
> > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
INTANGIBLE
> > LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE
PRINT
> > YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
DAMAGES),
> > RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL
BW,
> > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION
OF
> > YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD
> > PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
OTHER
> > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Links
