Fade test -- HP dye & MIS Ultra Tone pigments
2004-04-14 by Paul Roark
I just stopped my latest fade test (with a fluorescent light, "bare bulb")
at 600 hours. The results are below.
Short summary:
My initial conclusions are that the dyes on the latest papers are not bad,
but they are not in the same league with the best pigment-paper
combinations. The new Kodak paper does not appear to be a "breakthrough."
The Epson UltraSmooth paper (which I believe to be the same as Epson
Scrapbook and PremierArt Hot Press Fine Art) looks very solid. The Epson
Premium Semigloss, especially with PremierArt spray, also turned in an
excellent performance.
The Arches Hot Press uncoated paper did not do as well as the best coated
papers.
Notes on procedures:
HP dye was used on HP, Ilford Classic, and Kodak's latest paper. These were
supplied by 3rd parties.
All other papers used MIS Ultra Tone family pigments. The neutral curves
were used unless otherwise noted. The glossy papers with UT pigments used
the "Eboni-glossy" curves. (That is, the 100% black patch was composed of
the cyan and magenta position gray inks.)
Densities were read with an X-Rite Color Digital Swatchbook
spectrophotometer. Where there is a + or - sign, it indicates that some of
the multiple readings were at the next higher or lower, respectively,
number.
X-Rite readings:
HP dye on HP paper:
Cyan Mag. Yellow
Visual density
50% patch start: .80 .79 .76 .79
600 Hr: .78 .76- .72
.77
100% patch start: 2.06+ 2.05+ 2.03 2.05-
600 Hr: 1.97 1.95 1.92
1.95
Paper white: .07 .06 .05
.06
600 Hr: .07 .06 .05
.06
HP dye on Ilford Classic Pearl paper:
Cyan Mag. Yellow
Visual density
50% patch start: .54 .52 .51 .53
600 Hr: .50 .49+ .48-
.50
100% patch start: 1.62 1.60 1.56 1.60+
600 Hr: 1.66 1.64 1.59
1.64
(Dark storage control 1.69 1.69 1.65 1.68)
(A dmax increase during the first day of drying or "curing" is
not unusual.
All samples were over 1 day old. This amount of "curing" is
unusual.)
Paper white: .07 .06 .04
.07
600 Hr: .07 .06 .06
.07
HP dye on Kodak paper:
Cyan Mag. Yellow
Visual density
50% patch start: .58 .56 .53 .58
600 Hr: .55 .54 .51
.55
100% patch start: 2.15 2.07- 1.98 2.09-
600 Hr: 2.13 2.02 1.90
2.05
Paper white: .08 .08 .05
.08
600 Hr: .08 .07 .06
.08
MIS Ultra Tone inks on various papers:
Epson UltraSmooth:
Cyan Mag. Yellow
Visual density
50% patch start: .59 .59 .60 .59
600 Hr: .59 .59 .60
.59
100% patch start: 1.61 1.62 1.64 1.61+
600 Hr: 1.60 1.61 1.63
1.61
Paper white: .02 .03 .04
.03
600 Hr: .02 .02 .04
.02
Epson Premium Semigloss with PremierArt spray:
Cyan Mag. Yellow
Visual density
50% patch start: .58 .57 .58 .58
600 Hr: .58 .57 .58
.58
100% patch start: 2.07- 2.09 2.09- 2.08
600 Hr: 2.05 2.07 2.06
2.06
.06
600 Hr: .07 .06 .04
.06
Premium Semigloss with no PremierArt spray:
Cyan Mag. Yellow
Visual density
50% patch start: .60 .60 .60 .60
600 Hr: .60 .59 .60
.60
100% patch start: 2.10 2.11 2.09 2.11
600 Hr: 2.08 2.08 2.05
2.08
Paper white: .06 .05 .03
.05
600 Hr: .06 .05 .03
.06-
Epson Enhanced Matte, UT carbon (no color pigments):
Cyan Mag. Yellow
Visual density
50% patch start: .58 .63 .68 .61
600 Hr: .58 .63 .70
.60+
100% patch start: 1.65 1.67 1.68 1.66
600 Hr: 1.66 1.67 1.69
1.66
Paper white: .04 .04 .02
.04
600 Hr: .04 .04 .04
.04
Epson Enhanced Matte with UT neutral curve:
Cyan Mag. Yellow
Visual density
50% patch start: .61 .62 .62 .61
600 Hr: .61 .61 .63
.61
100% patch start: 1.65 1.66 1.68 1.66
1.66
Paper white: .04 .03 .01
.04
600 Hr: .04 .04 .04
.04
Arches Hot Press with PremierArt spray:
Cyan Mag. Yellow
Visual density
50% patch start: .60 .62 .64 .61
600 Hr: .59 .61 .62
.60
100% patch start: 1.44 1.45 1.47 1.44
600 Hr: 1.43 1.45 1.46
1.44
Paper white: .05 .07 .10
.06
600 Hr: .05 .06 .08
.05
Arches Hot Press without PremierArt spray:
Cyan Mag. Yellow
Visual density
50% patch start: .59 .61 .63 .60
600 Hr: .59 .60 .62-
.59
100% patch start: 1.51 1.52 1.54- 1.52-
600 Hr: 1.51 1.52 1.53
1.51
.06
600 Hr: .04 .05 .07
.05
Epson Glossy Paper Heavyweight with PremierArt spray:
Cyan Mag. Yellow
Visual density
600 Hr: .60 .60 .61
.60
100% patch start: 2.09+ 2.09- 2.04+ 2.09+
600 Hr: 2.08 2.07 2.03
2.08
Paper white: .03 .04 .03
.03
600 Hr: .04 .04 .05
.04
Epson Glossy Heavyweight without PremierArt spray:
Cyan Mag. Yellow
Visual density
50% patch start: .59 .60 .59 .60
600 Hr: .59 .59 .60
.59
100% patch start: 1.96+ 1.96- 1.93- 1.96
600 Hr: 1.96 1.96 1.93
1.96
Paper white: .03 .03 .03
.03
600 Hr: .03 .04- .04
.03
