Fade test -- HP dye & MIS Ultra Tone pigments (re-formatted)
2004-04-14 by Paul Roark
I just stopped my latest fade test (with a fluorescent light, �bare bulb�)
at 600 hours.� The results are below.
Short summary:
My initial conclusions are that the dyes on the latest papers are not bad,
but they are not in the same league with the best pigment-paper
combinations.� The new Kodak paper does not appear to be a �breakthrough.�
The Epson UltraSmooth paper (which I believe to be the same as Epson
Scrapbook and PremierArt Hot Press Fine Art) looks very solid.� The Epson
Premium Semigloss, especially with PremierArt spray, also turned in an
excellent performance.
The Arches Hot Press uncoated paper did not do as well as the best coated
papers.
Notes on procedures:
HP dye was used on HP, Ilford Classic, and Kodak�s latest paper.� The
printed test strips were supplied by 3rd parties.�
All other papers were printed with MIS Ultra Tone family pigments.� The
neutral curves were used unless otherwise noted.� The glossy papers with UT
pigments used the �Eboni-glossy� curves.� (That is, the 100% black patch was
composed of the cyan and magenta position gray inks.)
Densities were read with an X-Rite Color Digital Swatchbook
spectrophotometer.� Where there is a + or � sign, it indicates that some of
the multiple readings were at the next higher or lower number.
A drop in the 50% patch Visual Density reading may be the best indicator of
fade rate.
A change in the difference between the cyan and yellow readings for the 50%
patch and Paper white indicates the extent of yellowing.  A change in the
100% patch color will probably not be noticeable.
X-Rite readings:
HP dye on HP paper:
                       Cyan���� Mag.���� Yellow�� Visual density
   50% patch start:    .80����� .79������� .76������� .79
 ���������� 600 Hr:��� .78����� .76-������ .72������� .77
� 100% patch start:�� 2.06+� � 2.05+�  �� 2.03� ���� 2.05-
����������� 600 Hr:�� 1.97���� 1.95��� �� 1.92�����  1.95
������ Paper white:��� .07����� .06������� .05������� .06
 ���������� 600 Hr:��� .07����� .06������� .05������� .06
HP dye on Ilford Classic Pearl paper:
���������������������� Cyan���� Mag.���� Yellow�� Visual density
�� 50% patch start:��� .54�� �� .52������� .51������� .53
����������� 600 Hr:��� .50����� .49+ ����� .48-������ .50
� 100% patch start:�� 1.62���� 1.60 ����� 1.56 ����� 1.60+
����������� 600 Hr:�� 1.66���� 1.64� ���� 1.59�� ��� 1.64
(Dark storage control�1.69�����1.69���� � 1.65�� ��� 1.68)
(A dmax increase during the first day of drying or �curing� is not unusual.
 All samples were over 1 day old.� This amount of �curing� is unusual.)
������ Paper white:� � .07����� .06������� .04������� .07
����������� 600 Hr:��� .07����� .06������� .06������� .07
HP dye on Kodak paper:
�  50% patch start:��� .58����� .56������� .53������� .58
����������� 600 Hr:��� .55����� .54������� .51������� .55
� 100% patch start:�� 2.15���� 2.07-� ��� 1.98�����  2.09-
����������� 600 Hr:�� 2.13���� 2.02� ���� 1.90 ����� 2.05
������ Paper white:��� .08����� .08������� .05������� .08
����������� 600 Hr:��� .08����� .07������� .06������� .08
MIS Ultra Tone inks on various papers:
Epson UltraSmooth:
� �������������������� Cyan���� Mag.���� Yellow�� Visual density
�� 50% patch start:��� .59����� .59������� .60������� .59
����������� 600 Hr:��� .59����� .59������� .60������� .59
� 100% patch start:�� 1.61���� 1.62�� ��� 1.64���� � 1.61+
����������� 600 Hr: � 1.60���� 1.61�� ��� 1.63 ����� 1.61
������ Paper white:��� .02����� .03������� .04������� .03
����������� 600 Hr:��� .02����� .02������� .04������� .02
Epson Premium Semigloss with PremierArt spray:
�� 50% patch start:��� .58����� .57������� .58������� .58
����������� 600 Hr:��� .58����� .57������� .58������� .58
� 100% patch start:�� 2.07-��� 2.09� ���� 2.09-��  � 2.08
����������� 600 Hr:�� 2.05���� 2.07� ���� 2.06�� ��� 2.06
������ Paper white:��� .07����� .06������� .04������� .06
����������� 600 Hr:��� .07����� .06������� .04������� .06
Premium Semigloss with no PremierArt spray:
��� ������������������ Cyan���� Mag.���� Yellow�� Visual density
�� 50% patch start:��� .60����� .60������� .60������� .60
����������� 600 Hr:��� .60����� .59������� .60������� .60
� 100% patch start:�� 2.10���� 2.11���� � 2.09��  �� 2.11
����������� 600 Hr:�� 2.08���� 2.08� ���� 2.05�� ��� 2.08
������ Paper white:��� .06����� .05������� .03������� .05
����������� 600 Hr:��� .06����� .05������� .03������� .06-
Epson Enhanced Matte, UT carbon (no color pigments):
�� 50% patch start:�� .58��� � .63������� .68������� .61
����������� 600 Hr:�� .58����� .63������� .70������� .60+
� 100% patch start:� 1.65���� 1.67�� ��� 1.68�  ��� 1.66
����������� 600 Hr:� 1.66���� 1.67�� ��� 1.69��� �� 1.66
������ Paper white:�� .04����� .04������� .02������� .04
����������� 600 Hr:�� .04����� .04������� .04������� .04
Epson Enhanced Matte with UT neutral curve:
�� 50% patch start:�� .61����� .62������� .62������� .61
����������� 600 Hr:�� .61����� .61������� .63������� .61
� 100% patch start:� 1.65���� 1.66� ���� 1.68�����  1.66
����������� 600 Hr:� 1.66���� 1.67� ���� 1.69��� �� 1.66
������ Paper white:�� .04����� .03������� .01������� .04
Arches Hot Press with PremierArt spray:
��� 50% patch start:� .60����� .62������� .64������� .61
������������ 600 Hr:� .59����� .61������� .62������� .60
�� 100% patch start: 1.44���� 1.45 ����� 1.47� ���� 1.44
������������ 600 Hr: 1.43���� 1.45 ����� 1.46� ���� 1.44
������� Paper white:� .05����� .07������� .10������� .06
������������ 600 Hr:� .05����� .06������� .08������� .05
Arches Hot Press without PremierArt spray:
� ������������������� Cyan���� Mag.���� Yellow�� Visual density
��� 50% patch start:� .59����� .61������� .63������� .60
������������ 600 Hr:� .59����� .60������� .62-������ .59
�� 100% patch start: 1.51���� 1.52� ���� 1.54-� ��� 1.52-
������������ 600 Hr: 1.51���� 1.52� ���� 1.53 ����� 1.51
������������ 600 Hr:� .04����� .05������� .07������� .05
Epson Glossy Paper Heavyweight with PremierArt spray:
��� 50% patch start:� .60����� .60������� .60������� .60
������������ 600 Hr:� .60����� .60������� .61������� .60
�� 100% patch start:�2.09+��� 2.09-�� �� 2.04+�  �� 2.09+
������������ 600 Hr: 2.08���� 2.07�� ��� 2.03���� � 2.08
������� Paper white:� .03����� .04������� .03������� .03
������������ 600 Hr:� .04����� .04������� .05������� .04
Epson Glossy Heavyweight without PremierArt spray:
��� 50% patch start:� .59����� .60������� .59������� .60
������������ 600 Hr:� .59����� .59������� .60������� .59
�� 100% patch start:�1.96+��� 1.96-����  1.93-��� � 1.96
������������ 600 Hr: 1.96���� 1.96� ���� 1.93 ����� 1.96
������� Paper white:� .03����� .03������� .03������� .03
������������ 600 Hr:� .03����� .04-������ .04������� .03
