[Digital BW] Re: CIS with 1160
2004-04-17 by Mark Hahn
you essentially never need to replace your carts so long as ink will
pass through them.  If you decide that using the vacuum pump method
to fill them is the only way that you want to charge your system you
should be able to just plug them with anything you want (MIS supplies
aluminum rivets that could easily be purchased as a hardware store)
and redo that, but if you have ink in your tubes you have to go
through the whole hassle of cleaning or replacing them.  Personally,
I replace them.  I only used my vacuum pump for the first filling,
but had to replace tubes many times because the MIS black ink clogs
the tube.  There is no science to this stuff.  You need to get your
lines full and your carts about half full and then everything works.
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Glenn Barry"
<glennrbarry@o...> wrote:
> What about replacing the plugs in the bottom like those that were
available
> for the re-fillable (not-cis) carts, that will be cheaper than
replacing the
> whole cartridge system.
> Glenn
> From: "Andre" <am1000@v...>
> To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> Sent: Saturday, April 17, 2004 11:12 AM
> Subject: [Digital BW] Re: CIS with 1160
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "byushooter"
> > <jellerbe@j...> wrote:
> > > Thanks Andre for the quick reply.  Since the cartridges were
> > > installed and the bottom seal pierced, can I reuse them?  Can I
> > just
> > > tape over the bottom of them or something so that I can create a
> > > vacuum with the syringe?
> > > Thanks,
> > > Jenny
> > I'm afraid you may need a fresh set of cartridges because you
need to
> > put a vacuum in them so that they draw the ink from the bottles
> > through the tubes lines. And when you draw air from those filled
> > cartridges for said vacuum, you'll have ink overflowing into your
> > siphon! Also, I dont know if the tape of the bottom would hold
when
> > you start that vacuum. I fail to see how it could be done
otherwise,
> > but you never know, maybe someone will explain how to do it.
> > Read the pdf carefully and make sure you understand the entire
> > procedure before you start and take your time.
> > Cheers,
> > Andre
> > Please visit the Group Homepage to check the Files, and other
resources as
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you
wish to
> unsubscribe, please edit your Membership preferences by visiting
this same
> page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier
messages to keep
> them short.
> > - Good manners are required at all time. No personal attacks or
flames.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> > - Keep your posts and threads related to the group topic of
digital B&W
> printing. Users who persistently make off-topic posts may be
removed from
> the membership.
> > - By posting on this forum you agree to abide by the group rules
and
> guidelines, and to abide by the actions and decisions of the group
Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
THE PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED
OF THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
INABILITY
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Links
Re: [Digital BW] Re: CIS with 1160
2004-04-17 by Glenn Barry
What about replacing the plugs in the bottom like those that were available
for the re-fillable (not-cis) carts, that will be cheaper than replacing the
Glenn
> just
> > Thanks,
> > Jenny
> I'm afraid you may need a fresh set of cartridges because you need to
> siphon! Also, I dont know if the tape of the bottom would hold when
> you start that vacuum. I fail to see how it could be done otherwise,
> Cheers,
> Andre
page.
them short.
the membership.
