Filters and their split channels "equivalents"
2004-04-18 by Steve Kale
Hi all
Without sparking a debate about whether one must capture with B&W film (to be pure) can
I ask a few questions regarding the use of colour filters in B&W photography and their
(loose?) equivalents in raising or lowering the opacity of a red, blue or green layer when
using split channels for B&W conversion of a colour capture?
[Prior to moving to the digital domain I did not do much B&W photography because I was
always very disappointed with the proof sheets I got back from the lab.  Although I agree
that a lot of this was likely due to the poor development of film by the lab (and I have
taken on the comments from this group earlier re developing my own film etc) I am still
enjoying the B&W printing of images originally captured with colour fim (mostly Velvia or
Provia).]
I was surprised the other day when I saw a poster of an image by Ansel Adam of (I believe)
Mt McKinley (?).  The skies really were a deep deep black.  Also I just read yesterday the
small section in his Book 1 The Camera re the use of filters, particularly the reference to
using a No. 25 (A) Red filter for strong contrast in landscape photography.  And so I
turned back to one of my favourite images taken in the Grand Teton National Park and
how I had previously ranked and weighted the Red, Green and Blue (and Luminosity) layers
when converting to B&W.  Specifically, I found that to approach the massive punch I saw in
the Adams print I had to use the Red layer as my base at 100%, with only slight if any use
of the Green and no use of the Blue layer.  (Adjusting the Luminosity layer from LAB
seemed similar to adjusting Green.)
So I am now trying to understand filters a bit better.  As I understand it a Red filter will
allow red light to pass easily but will block (and hence darken on B&W film) its
complementary colour.  Is the "complementary colour" both blue and green?  Hence, is
stripping out the blue and green channels the loose equivalent of using a strong red filter?
What about a deep yellow filter No. 12?  Mix green and blue and one gets yellow right?
What is the complementary colour of yellow?   Sorry, I am sure this stuff is very basic - my
knowledge of colour theory extends only to the very limited stuff I can remember from
primary school.  If any colour in the visible spectrum can be made up from a mix of Red,
Green and Blue (isn't this the basis of RGB colour space?) then any colour filter can be
simulated by altering the weighting of red, green and blue from the original capture?
(ignoring for now effects from non-visible parts of the spectrum eg infra-red)  In
traditional B&W photography the workspace is a film/filter selection process (assuming
correct exposure etc).  I am trying to understand what happens to the RGB light mix
hitting the film plane when a filter is used and I guess how this alteration might be
simulated in a workspace like Adobe RGB where rather than limiting particular parts of the
spectrum hitting the film plane we limit them afterwards in a virtual world.
(I understand that all films have different sensitivities to the various parts of the spectrum
and that by shooting in colour (or for that matter any) film I immediately limit my future
options to the "space" able to be captured by that film.  But it seems to me that one
advantage of colour capture is that the range of adjustments that can be made post
capture is significantly greater than those that can be made with B&W film.  With B&W film
all the decisions regarding filtering the RGB spectrum must be made prior to pressing the
shutter.  If you block the blue at capture it is gone forever and you could never produce an
image with an overweight blue composite from that capture.)
Any help or references to useful (digestable) reading material would be greatly
appreciated.
Steve
Re: [Digital BW] Filters and their split channels "equivalents"
2004-04-19 by Don M
>a Red filter will
>film) its
>green?  Hence, is
>strong red filter?
>yellow right?
A filter will pass light of its own color and of the "adjacent" colors on a
color wheel. It blocks some or almost all of the light from the other
colors.  The darker (intensity) the filter, the more it blocks.
A sky is closer to cyan than blue. Red is opposite cyan, so it darkens
skies the most.   Deep yellow will be more opposite from blue than cyan, so
it won't darken the sky quite as much.  But still a fair amount.
Darkening an overcast sky is another matter entirely, since it is
gray.  You have to use a neutral density filter there.
Also, when using a filter with film, you have to increase exposure because
of the darkening effect of the filter.  This means you let more of the
matching filter color in than if you had not increased the exposure.  That
is why a filter will "lighten" objects of its color.
I would think you are on the right track regarding the color channels idea.
Instead of PS, I use Picture Window Pro, which allows the application of
colored filters to the BW image, giving the effect you are looking
for.   If PS doesn't do it, there must be plug-ins.
-Don M
