C84 or C82 ?
C84 or C82 ?
2004-04-20 by sl91911
I have seen the posts regarding the new EZ black and white process. I
have access to bot a C82 and a C84.
Which is the best to use with this process ?
If there a difference with ink usage on the two (there are other posts
by users on this issue) ?
                            Stuart
RE: [Digital BW] C84 or C82 ?
2004-04-21 by Paul Roark
Stuart,
>... regarding the new EZ black and white process. I
The C84 seems to print at a higher contrast than the C82.  The C82 output
matches my CRT better, but the C84, with the driver contrast slider pulled
down a bit to open up the shadows matches the LCD displays I have better.
The C82 under-prints the black with color ink.  So does the C84 most of the
time.  This lowers dmax.  On EEM and PhotoRag it's still OK, but on some
other papers it's marginal.  The C84 on Plain Paper setting does not
under-print the blacks.  As such, the C84 with Plain Paper setting gets as
good a dmax as the more expensive printers.  I have not been able to test a
C82 to see if that is also the case with that printer.  If someone out there
can just print and compare some 100% black patches with EEM and then Plain
Paper settings on EEM, we might be able to tell.
(I don't know about ink usage, I'd assume it is the same.)
Re: [Digital BW] C84 or C82 ?
2004-04-21 by sl91911
Paul,
Thank you very much. It sounds like the C84 is the way to go.
   Stuart
<paul.roark@v...> wrote:
> Stuart,
output
pulled
better.
of the
gets as
test a
out there
Plain
> Paul
> www.PaulRoark.com
