Thanks Daniel,
It must be the hidden slection which I had forgotten about as I
flattened the image before sharpening. One of the last steps in the
edge sharpening workflow I used was to hide the slection -- "hide
edges."
By the way, I used the edge sharpening workflow found at
www.bythom.com/sharpening.htm. While it is the first I have tried,
it worked quite well and using levels it is easy to control what is
sharpened and what is not.
Steve
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel Staver"
<daniel@p...> wrote:
> > I tried edge sharpening using a channel mask with nice results on
a
> > portrait. However, when I converted to RGB and tried to apply
> > Roark curves (MIS VM on a 1200) I got very strange results. It
> > appears that the colors only "took" on the portions that had been
> > sharpened, that were black on the mask. It printed strangely.
When
> > I applied the curves to a copy that had not been sharpened, it
looked
> > normal. Any ideas about what I missed?
> Sounds like one of your adjustment layers are interfering with the
> curve. Make sure the curve is the top layer, or flatten the image
before
> you apply the curve.
> Or maybe you forgot to deselect a hidden selection before applying
> curve? In that case CTRL-D should do the trick.
> Daniel Staver
> http://daniel.staver.no
