Re: [Digital BW] Re: Can I get a nice neutral black and white print from the 2200?
2004-05-14 by Steve Kale
Lynne Back to the original question. Yes you can get great B&W with the Epson 2200 printer that you OWN TODAY. A custom profile will improve the colour output but will do little for your black and white. I custom profile my printer with the Gretag Macbeth Eye-One. A B&W print with a profiled 21/2200 using the Epson driver will still exhibit metamerism. The good news is that there exist simple means of getting rid of this problem WITHOUT spending a lot of additional money. Start with Roy¹s QTR and your existing inks. It costs nothing but a little time to give it a go. I can tell you that the difference between QTR and the Epson driver is night and day. The principal reason is that QTR has dedicated control over the individual inks, balancing light magenta and light cyan evenly and not using any yellow. If that doesn¹t do it for you then you are into different inks and dedicating your printer to B&W eg the new UT7 inks developed by Paul Roark. Give it a whirl Steve
From: "Scott Graham" <gebilwil@...> <The solution is a custom profile for your paper.> <Or if you can afford a 4000, I highly recommend it.> Scott PS: you could also go black only, but I consider than an inferior compromise, and the Epson black is a bit warm. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lynne Siler" <lhsiler@b...> wrote: > I tried using a Epson 1270 with Lyson quad blacks last year, and the prints > started fading within months! So I happily bought the 2200 and am happy for > the most part, but cannot seem to get consistent results when printing black > and white images. I've thought about buying another 2200 and looking into > 3rd party inks again, but after getting burned by the Lyson inks I'm not sure > where to go with this. What are most of you doing for nice B&W prints? I'm > using epson velvet for most prints and print mostly portraits. > > Thanks, > Lynne Siler [Non-text portions of this message have been removed]
