Re: [Digital BW] 8oz see through carts
2004-05-20 by Glenn Barry
Here are some observations from Ernst Dinkla when i inquired about the same
carts on E-bay
You can use 9000 carts in the 3000. A guiding tab has to be cut
on the cart to get them in a 3000. But all the functions will be
there including the hardware triggered empty warning. Refilling
with a syringe + 0.8 mm (shortened) needle is quite easy. 220 ml
ink, about 190 ml used per charge. That's twice the normal 3000
amount.
I have no experience with the carts on the site you mentioned.
But checking their images:
There will be no hardware triggered empty signal.  In the worst
case you could run the inkchannel dry.
Air has to get into the rigid cart to avoid the creation of a
vacuum while printing. Not that much of a problem with pigment
inks but not so nice for dyes. The Epson carts have a pouch
inside that flattens and no air has to get  into the ink
container itself.
That brings me to what I see as the main disadvantage of that
cart, you can't use it till it gets completely empty, half of the
cart below the seal where it is connected to the Epson inkline
will never be used and while it prints from full to half cart
content the ink pressure changes with the ink level. Both issues
don't happen with the Epson carts.
Refilling might be easier though.
If there's a bag in that cart too then most of the problems I
sketched are not there. But its transparency doesn't show a bag
like that.
Ernst
and this also
But I have to correct my observations on one aspect: it will
empty the cart almost totally as there's a kind of siphon
construction in the cart near the connection seal. But on the
other hand that construction means that there's a ink level
change of approx. 10 cm in the time it is used, which will result
in a bigger change in ink pressure at the heads.
Ernst
Sent: Friday, May 21, 2004 8:55 AM
Subject: [Digital BW] 8oz see through carts
> I'll try this again. Has anyone had experience with these 8oz see
> through Carts? Pros and Cons. Any possibility of pressure difference
> between carts and heads, which would lead to siphoning action
> draining carts? I am using a 7500. Anyone else selling these.
> http://www.inkmizer.com/Delivery%20Systems.htm
they are often being updated.
page.
them short.
membership without notice.
the membership.
