Epson 2100 BO printing --> mysterious dot patterns ?
2004-05-31 by grethabakker
Group,
Just to let you know:
As an BO printer (2100+ MK and Eboni) on art paper who was evaluating
his prints, I noticed a slight irregularity in the lighter grey areas
(40% and less). The longer I looked, the more irritated I become.
I did some testing with printing a step wedge, and learned that using
the Epson watercolor-radiant profile (that was my default) caused
irregulair and ugly dot patterns in the lighter areas.
When I use the EEM profile, I get smooth dot patterns. I now switched
to EEM profile after some dot gain tweaking.
But then I read the memo of Clayton in which he mentioned "tiny
double dots" when printing with thick paper through the back feed.
I realy want to understand this effect so I can reproduce it. Is it
profile based ?
Because with my 1290 I also experianced this effect, but never knew
where it came from and assumed that it was a temporarely failure of
the printhead. I am that curious, because I liked this dot pattern
because of its smoothness in the lighter areas.
Another question: I have found some additional Epson paper profiles
on the australian Epson site which are not standard installed (?)
with my 2100 software. Where do I have to place them so my printer
software will find it ?
Best regards,
http://home.wanadoo.nl/rene.r.bakker/
Re: Epson 2100 BO printing --> mysterious dot patterns ?
2004-05-31 by Clayton Jones
Hello Gretha,
>using the Epson watercolor-radiant profile (that was my default)
>caused irregulair and ugly dot patterns in the lighter areas.
>switched to EEM profile after some dot gain tweaking.
>it profile based ?
No, in my case it is not - I don't use paper profiles.  My techniques
are described in articles # 3 and 4 on the web link below.
As for the double dots, I don't notice much if any difference in the
over all look of the print.  It's only noticible with a loupe.
Clayton
2004-06-01 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...>
wrote:
> Hello Gretha,
> >it profile based ?
> Regards,
> Clayton
Those double dots are weird.  It's been a while but I'm pretty I had
the same thing on my 1160 with the Epson driver.
Roy
2004-06-01 by Clayton Jones
Hello Roy,
My 870 used double dots.  I took it for granted until I got the 2200
and realized it didn't have to be.  Now here they are again on manual
feed prints.  Perhaps it uses a pair of smallest possible dots instead
on one larger one to lessen dot gain on thick papers which might be
uncoated...
I got them one other time, during experiments last year with chips and
carts.  I can't remember exactly what it was, either putting Museum
Black in an Epson MK cart or putting a PK chip on an Eboni
cart...something like that.  Doesn't seem to be a problem.
Clayton
