Mounting 24x36 inch Prints on Thin Aluminum Sheets
2004-06-01 by alland20854
As noted in my other message on Renaissance Wax I would like to mount 24x36 inch
Ultrachrome prints on thin aluminum sheets for exhibition. Questions:
1. What type of adhesive can I use that will be reasonably archival, and likely to be
available in Bangkok?
2. How can the prints mounted on the aluminum using the adhesive you recommend? Can
it be done by hand pressure? With a roller? With a laminator? (A hand or hand-roller
solution would be the simplest for me.)
--Mitch/Bangkok
