How does UT2 work without curves?
2004-06-10 by Peter A. Klein
Forgive my asking what may be an obvious question to some.  I'm aware
that the UT2 inks can make a good B&W print without using false-color
curves.  But how does it work when you don't use curves?  How does
the driver know in what proportion to mix the different inks to
produce the various shades of gray?
Also, are prints produced using the curves better than ones produced
without them, or is it about the same?
I plan to switch to UT2 once I get my 1280 cleaned and use up my last
UT1 cartridge.
--Peter
