regarding ut2 inks and the 1270 printer /curves
2004-06-18 by image2layer
ADJUSTMENT CURVES ON THE EPSON 1270 PRINTER I purchased my 1270 epson printer off of eBay and installed the The MIS UT2 and ebony black cartridges for black and white printing. MIS recommended the UT2 cartridges for the 1270. I used epson archival matte paper. With no curves the prints were ok. Once the curves were loaded into Adobe Photoshop the prints came came out posterized. Even when switching from 8 bit to 16 bit mode, there has been the problem with posterization. I have been able to control this problem by adjusting the opacity of the layers that the curves are downloaded into. Could there be a problem with my settings or could this be a problem for this particular printer? How I Solved the Problem and What do You Think About this Technique? Here is how I solved the posterization problem for the epson 1270 printer. Curves loaded from Paul Roarks curve collection were put on an ajdustment layer in Photoshop. Opacity of the curves layer was put at 33% or lower. By doing this I could warm or cool my prints to a small degree. I kept a second curve of my own from which I adjusted the tonal scale of the print. This may be a more limited way to adjust warmness and coolness of prints, but it does appear to work. It may be that to get the full potential of these inks, a newer and better 1280 printer would be better than the 1270. All the pieces of the puzzle are not quiet together yet. I may regret that I did not get a 1280 and decided to save money. I have checked the forum and little has been said about using adjustment curves and varying them with opacity layers. To my knowledge you should be able to just load the adjustment curve and it should work fine. I have been able to make some good prints. Its consistent. Could it be that the printer has a bad cart, the printer has a problem or the settings are not quiet right? Has anyone had a similiar situation with a 1270 printer? I like the idea of making 2 separate layers for curves, one for adjusting the tonal scale and the other for adjusting the warmness of the print. Is there a reason not to do this? Is it possible to make decent glossy prints. I read through some forum discussions. Paul Roark does not seem to endorse it. Are there other options than matte that seem to work ok? Thanks. Dave
