I personally haven't had any significant clogging problems with the UT7
inks, but I'm using refilled Epson carts, so my setup is a little bit
different.
I have had some problems getting the print head aligned properly after I
got the UT7 inks though, although right now everything seems to work
reasonably well. Not sure if this was an ink problem or just my printer
being difficult.
I've never used flush carts when switching from Epson to MIS inks, but
it takes several cleaning cycles to get rid of all the color, so you
probably don't want to do the switch too often to avoid wasting ink.
Try to ask MIS if they have the refill friendly 2200 carts available.
Bob mentioned a few weeks ago that they were expecting to get those
cartridges any moment. If you refill from bottles the ink price is
reduced to around 1/5-1/10 of the prefilled cartridge price.
Also try their forum:
http://www.inksupply.com/forum/index.php
I find it's a great place to get support for their products.
Daniel Staver
http://daniel.staver.no
byten2003 wrote:
> Well, I am looking at the 11x17 portrait I was in the process of
> making when I had so much trouble. Even with the epson matte black
> cart mixed in with the UT7 this print is stunning.
> Guess I'll just have to pony up the dough even if I eventually fry
> the head on the 2200 and have to replace it. It is worth it to me
> for the great black and white prints I am able to produce.
> It seems like the big trouble occurs when I change from epson ink to
> mis. Is it possible that even with the ut7 I should use a set of
> flush carts in between?
