Using UT2: RGB to grayscale to RGB?
2004-06-22 by deskofjk
I'm starting with an RGB full color image and I want to convert it
to black and white and print after loading Roarke's  UT2 curves.  If
I just desaturate the color to get a black and white image, there's
still information in each color channel which seems to screw up the
curves (when I load them and print I get a useless image, ie few
grays, heavy black, white, etc).  I can solve this problem by going
to image ->convert to grayscale and then image-> convert to RGB and
then loading the curves. But I understand that I'm losing image data
by converting back and forth between RGB and grayscale images.
What's the best way to convert to grayscale if I'm starting with
with a color RGB image and want to print a black and white image in
RGB mode using UT2 curves?
Great Thanks, Jonathan
Re: Using UT2: RGB to grayscale to RGB?
2004-06-22 by Andre
Jonathan,
While the image needs to be converted to greyscale, it doesnt need to
be in greyscale mode. You can stay in RGB mode all the way. I've just
tried it although I usually work with a scanned greyscale mode image.
There are dozens of recipe to convert from color to greyscale. Here's
one that I sometime use: Convert by adjustment layers.
http://www.thelightsright.com/DigitalDarkroom/PhotoshopTools.htm
Don't forget to merge all layers before applying Paul's Adjustement
Printing Curves. The image on the screen will then take on weird
colors but will make a nice print.
Andre
2004-06-22 by Andre
And I should have given the following links to Paul's site where
there is info on printer settings for the UT familly inkset.
http://home1.gte.net/res09aij/
Andre
2004-06-22 by Gareth
I work in RGB all the way through my workflow, especially when I used
to have PS7 and use 8bit for everything.  I now have PSCS so no
problems there!
8bit RGB allows you to do more destructive adjustments than 8bit grey
even though all 3 channels have exactly the same numbers in the
channels.
You shouldn't need to go RGB-GS-RGB.
HTH
Gareth
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "deskofjk"
If
data
2004-06-22 by Jerry in Houston
Everyone seems to have their fave color->greyscale
conversion technique, and I do too.  I have tried all
of the ones in PS7 and several other techniques I
found in PS technique sites.  I have settled on the
Russell Browns' technique which seems to give me more
control over the conversion.  I also use the UT2 CFS
from MIS on my 1280.
Jerry in Houston
 <<Date: Tue, 22 Jun 2004 06:19:04 -0000
Subject: Using UT2:  RGB to grayscale to RGB?
to convert it
UT2 curves.  If
image, there's
screw up the
image, ie few
problem by going
convert to RGB and
losing image data
images.
starting with
white image in
Great Thanks, Jonathan>>
