I believe the consensus is that the Canon heads require inks that are too
thin to keep pigments properly suspended in the medium during the life of a
cartridge (or something like that.) In any case, I've never heard of
anyone offering pigments for the S900/9000 printers, or for other Canons
that use the same print head. I do note that the low end Canon photo
printers (560, 860) apparently use a special pigmented black ink to get
better looking text output, but a look at the specifications on those
printers shows what appears to be a lower resolution for black than for the
color inks, which are the same BCI-6 inks as the S9000 uses.
AFAIK, if you want to use pigments, Epson printers are the only choice at
the moment.
Kip
At 6/23/2004 12:37 PM +0000, you wrote:
>Dont know about the UT2 inkset in a Canon printer, but over at
>Inkjetmall.com they have been trying for about 18 months to use the
>PiezoTone carbon pigment inkset with Canon printers and they have not
>succeeded yet. Could be that the Canon printer's head cannot accept
>carbon pigment inks which is what the UT2 inkset are made of.
>Cheers,
>Andre
