mike and daniel,
many thanks for your comments about ultratone, etc.
can you clarify a few things?
1. you both said 2 head cleanings are necessary when switching inks. do you mean
running the epson utility head cleaner, or are you talking about using some flush carts?
2. daniel (below) refers to BO prints. what are they? surely you don't mean black only? if
you're doing black only prints, why would you be using UT inks? just to get carbon rather
than dye based?
3. daniel says he fills his own epson cartridges with MIS ink. any pointers on how to do
that?
4. i'm still curious about dmax. with my QTR on epson enhanced matte, i still get a print
that has nothing like the depth of black that i used to get on my old selenium-toned,
fibre-based wet darkroom prints. am i expecting too much? is it hopeless to even try and
approach that? i've heard people say that the paper is more a factor in dmax than the inks,
and the epson dye inks actually give better dmax than the carbon-based inks. any
comments?
/daniel
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Staver <daniel@p...>
wrote:
> > 1. has anyone seen an ultratone-7 print and compared it to a piezography print?
> > 2. how about Quad RIP? i've seen roy harrington's scans on the web,
> > but i'm still curious to know how the overall print appears in
> > ultratone-7 versus Quad RIP.
> I use the UT7 inks myself, with both the Epson driver and with QTR. I
> have also seen numerous Piezo prints in exchanges.
> You'd be hard pressed to tell the difference between a well done print
> made with any of these three workflows, but the UT7 inkset has the
> obvious advantage of allowing you to vary the tone of the print from
> cool to strong sepia. UT7 also has great performance on glossy papers.
> That, combined with the much lower prices of the MIS inks makes the UT7
> inkset the obvious choice for me.
> The advantage of QTR isn't so much that the quality of the final print
> is any better or worse - it's actually very similar to the Epson driver
> - it's the excellent profiling tools and the very detailed controls over
> each ink position it gives you that makes it worthwhile. If you're into
> making custom profiles, mixing your own inks or just want more control
> of the printmaking process in general then QTR is definitely the right
> tool for the job.
> That said, the UT7 inkset and the Epson driver is also much better in
> this regard than it used to be. Paul has done a great job on making the
> inkset easy to use and control - you get excellent prints just using the
> driver controls and no curves, and still have a large selection of
> curves available for various papers if you need that too.
> > 3. have people had head clog problems with ultratone inks?
> No clog problems for me, but I have experienced some banding problems
> that I've mostly managed to solve. Prints on EEM, Photo Rag, Ilford
> Smooth Pearl and Somerset Velvet all looks excellent with no banding
> now. With BO prints I can still see some slight dither banding, and I've
> also had problems on Condor. Not sure if this was because of the inkset
> or if it was just my printer being difficult.
> > 4. do the ultratone cartidges suffer from the same reporting problem as the
piezography
> > ones (not reporting accurate ink levels)?
> I can't answer that, I'm using refilled Epson cartridges instead of the
> MIS cartridges.
> > 5. is it really true that you can just put in the ultratone cartridges without flushing out
> > ultrachrome inks?
> Yes, like Mike said it typically takes 2 cleanings to make the switch.
> Daniel Staver
> http://daniel.staver.no
