Help on QTR file preparation
2004-08-10 by Bailey Donnally
What am I doing wrong?
I installed QuadToneRip on my computer running Windows XP home and no
error messages showed up.  I dragged the 21step.tif gray scale file
into the Print-2200.bat icon and the grayscale printed out perfectly
on the Epson 2200 printer.  I tried various warm, cool, coolSe and
Sepia profile combinations and they worked as advertised.  I could
move the image on the page using margins specification.
Then I took one of my own images and in Photoshop CS flattened the
image, changed it to grayscale mode, changed it to 8-bit color, set
the size to what I wanted and saved it as an uncompressed TIF file.
I dragged that image to the Print-2200.bat icon and it printed out
beautifully.
That is the end of the happy story.
Every other image that I have tried to print with this procedure
(with an exception that I will mention later) has failed.  Everything
seems to work fine except that it gives a nonsense printout.  The
size of the image prints out correctly, the placement on the sheet is
OK.  But what prints out within that rectangle is a mess, often with
stripes in it, and with no hint of the original image.
I saw that Roy had put up a version 2, so I removed all the original
QTR programs and all the profiles from my machine and downloaded and
installed version 2.  Nothing changed.  All symptoms were the same.
I tried saving the images from Photoshop CS as a compressed (LZW) TIF
file and as an uncompressed TIF file.  I tried various sizes for the
image.  I tried several different resolutions, including some within
and some outside of the recommended range of 240ppi to 720ppi.  No
improvement.
The exception to this string of failures was this: I wondered if all
that extra information that is included in a TIF file could be
messing up the process so I took a JPEG image, loaded it into
IfranView, changed to grayscale, and saved it as an uncompressed TIF
file.  When I dragged this image to the Print-2200.bat icon it
printed out properly on letter size paper.  Later I brought this
image into Photoshop, chose not to color manage it, changed the size
to 18" x 12" to fit on a SuperB paper, saved it as uncompressed TIF.
This printed out OK on SuperB paper.
What is going on here?  What am I doing wrong?  What I told you
suggests that I am not preparing the images in Photoshop properly,
but I don't know where I am going wrong.
Bailey Donnally
Re: Help on QTR file preparation
2004-08-12 by Bailey Donnally
Fortunately I have found the answer to my problem in printing with
QTR.  You have to get rid of any alpha channels before you save as a
TIF file.  If you have saved a selection, for example, you create a
channel which will be saved by TIF and which will then screw up the
printing process with Windows QTR.
Bailey
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bailey
no
perfectly
file.
> beautifully.
Everything
is
with
original
and
same.
TIF
within
> improvement.
all
TIF
size
TIF.
> Bailey Donnally
