RE: [Digital BW] Solved! Re: Quadtone RIP for WinXP: "Some level of networking" Question
2004-08-11 by Richard Wolfson
I have not tried this -- and I'm not sure how Roy's software is
interacting with networking -- so what follows is speculation:
To set up your "one computer network" it may be necessary to plug the
Ethernet port in your computer (assuming there is one...) into a hub
with a short cat 5 network cable. Otherwise, Windows may not be able to
configure local networking. If your only network device is your phone
connection ("dial-up adapter" in windows jargon) the networking
configuration Roy's software needs may vanish each time you disconnect
your dial-up connection.
Richard Wolfson
> From: Andrew Unger [mailto:ungram@...]
> Sent: Tuesday, August 10, 2004 8:55 PM
> Subject: [Digital BW] Solved! Re: Quadtone RIP for WinXP:
> I'm following the QTR threads so that I'll be ready when Roy has
> 4000-Windows enabled.  I have a phone connection and really don't
> want it to have to be on all the time QTR is printing.  It is
> possible to set up a one computer network using the Network Wizard.
> Select "other" to describe the connection, then "this computer
> directly connects to the internet, I don't have a network yet."  Go
> through the balance of the screens and you should then have your one
> computer home network.  I'm hoping that simply having the network
> created and printer sharing enabled will be enough so that you don't
> have to actually be online and thus "networked."
> Andrew
2004-08-16 by Andrew Unger
Has anyone tried Richard's suggestion with success?  That is, using
the Win Network Wizard to configure a one computer network, then
adding the cable from the the Ethernet port to a hub.  Its a cheap
solution if it works.
Andrew
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Richard
hub
able to
phone
disconnect
> Richard Wolfson
> > From: Andrew Unger [mailto:ungram@y...]
Re: [Digital BW] Solved! Re: Quadtone RIP for WinXP: "Some level of networking" Question
2004-08-16 by Brentley Beerline
Actually all that is required is to add a loopback adapter with a
localhost address.  I can build a doc that demonstrates this if
demand is there.
regards
Brentley
2004-08-16 by johnglodge
WinXP and Win2K have software loopback adapters all you need to do
is install what is alreay there
...John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Brentley
> demand is there.
> regards
> Brentley
using
cheap
2004-08-16 by Stephen Billard
I'd appreciate this, then I can pass it on to people who can't get
QTRgui/QuadToneRIP to work because of no Shared Printer.
-Stephen
 www.sbillard.org/Stephen
> From: Brentley Beerline [mailto:brentley_beerline@...]
> Sent: Monday, August 16, 2004 1:40 PM
> Subject: Re: [Digital BW] Solved! Re: Quadtone RIP for WinXP:
> with a localhost address.  I can build a doc that
> demonstrates this if demand is there.
> regards
> Brentley
> Yahoo! Domains - Claim yours for only $14.70
> http://us.click.yahoo.com/Z1wmxD/DREIAA/yQLSAA/ucIolB/TM
> If you wish to receive no emails or just a daily digest, or
> you wish to unsubscribe, please edit your Membership
> preferences by visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks
> or flames. Hostile, aggressive or argumentative users may be
> removed from the membership without notice.
> - Keep your posts and threads related to the group topic of
> digital B&W printing. Users who persistently make off-topic
> posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group
> rules and guidelines, and to abide by the actions and
> decisions of the group Owner and Moderators. See "Group
> Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
> BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE
> THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT,
> INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
> IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
> THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO
> THE DIGITAL BW, THE PRINT YAHOO GROUP.
2004-08-17 by Roy Harrington
A number of people would benefit from this loopback feature.
This is the microsoft link describing the setup -- use manual installation.
http://support.microsoft.com/?kbid=236869
Since my system has the network I don't know if there are any stumbling
blocks in getting this to work.
I'd be glad to include anyone's description of the whole process in the info.
Posting it here first would be helpful to most.
BTW, I'll be out of town for the rest of the week so replies will be delayed.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Billard" <stephen@s...>
> -Stephen
> > From: Brentley Beerline [mailto:brentley_beerline@y...]
> > regards
> > Brentley
> > Yahoo! Groups Links
2004-08-17 by njfranknj
I just followed the directions and it worked! I've been having
problems all day with some kind of network error, despite having torn
out, downloaded and reinstalled QTR3 for Windows. Now my file is
actually sent to the printer and I'm back where I was before the
network erupted - I get 1/4 of the image centered near where the whole
image should have appeared!
Well, one thing at a time, I guess. Now Roy's going away, so I'll get
a break from this headache, but it sure would be nice to have someone
to bitch at right now.
Anyway, thanks, Roy! Have a good whatever. BTW, changing the canvas
size of my image to make it smaller than the Epson's maximum had no
effect.
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
installation.
the info.
delayed.
> Thanks,
> Roy
> > -Stephen
> > > regards
> > > Brentley
using
cheap
> > > Yahoo! Groups Links
2004-08-17 by Maris V. Lidaka Sr.
Or, for Windows XP specifically:
http://support.microsoft.com/default.aspx?scid=kb;en-us;839013
(I didn't check to see what, if any, differences there are).
Maris
  Sent: Monday, August 16, 2004 8:04 PM
  Subject: [Digital BW] Solved! Re: Quadtone RIP for WinXP: "Some level of networking" Question
Hi Frank,
I'll give you one more shot before I leave.
If you are getting 1/4 of the image, I'm pretty sure what's happening is
the program is seeing too big an image than it thinks fits on a page
and chopping it up in tiles.  You'd probably get 4 pages output if
there's paper in the feeder.
I think using PS to position as well as QTR to position is causing confusion.
QTR doesn't know that you have a bunch of white around the image.
I think you'll have the easiest success if you just trim off all the extra white.
Then the default is to just center the image on the paper.   If you want
custom positioning then use the margin variables TOP and LEFT to specify
the top left corner.  It's very much like the Epson driver positioning.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "njfranknj" <njfranknj@y...>
> effect.
> Frank
> installation.
> the info.
> delayed.
> > Thanks,
> > Roy
> > > -Stephen
> > > > regards
> > > > Brentley
> using
> cheap
> > > > Yahoo! Groups Links
2004-08-17 by Stephen Billard
You sure you made it small enough? I had exactly this problem when I was
trying to print files that were to large to fit within the printer margins.
-Stephen
> From: njfranknj [mailto:njfranknj@...]
> Sent: Monday, August 16, 2004 7:17 PM
> having problems all day with some kind of network error,
> despite having torn out, downloaded and reinstalled QTR3 for
> Windows. Now my file is actually sent to the printer and I'm
> back where I was before the network erupted - I get 1/4 of
> the image centered near where the whole image should have appeared!
> I'll get a break from this headache, but it sure would be
> nice to have someone to bitch at right now.
> canvas size of my image to make it smaller than the Epson's
> maximum had no effect.
> Frank
> installation.
> any stumbling
> the info.
> delayed.
> > Thanks,
> > Roy
> can't get
> > > -Stephen
> > > > regards
> > > > Brentley
> using
> network, then
> cheap
> > > > Yahoo! Groups Links
