Re: [Digital BW] Scanning Black & White Negatives
2004-08-14 by B. Campbell
>I currently have an Epson 2450 scanner which works "ok" for medium >format transparencies. When I attempt to scan b&w negative film >however, the results are horrible. Here is my two current questions. It would be helpful to know in what way your results are "horrible." However, if you can print B&W fine from desaturated (desiderated?) color negatives but not from b&w negatives and if your negatives appear as negatives when opened in Photoshop, it sounds like one or more of your settings in Vuescan may be wrong. What settings are you using in the "Device" tab? "Scan Mode" should be "transparency," "Media Type" should be B/W Negative, "Bits Per Pixel" should be 16 bit gray. Preview Resolution should be something very low to speed things along, I use 100 dpi, Resolution should be whatever you want, presumably the max that the 2450 is capable of with a medium format negative. Then under "Color" tab set your film type, if your film isn't there try setting it for T Max 100, set your CI (around .55 is a good place to start with a normal negative). The three colors are all set to 1, set your black and white points based on the preview histogram or as a place to start you could just use 0 for black and 1 for white. See what happens. If by "Quadtone for Windows" b&w printing software you mean Roy Harrington's new QTR then someone else will have to help you with that, I haven't yet tried it yet.
----- Original Message ----- From: "btvarner" <btvarner@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Friday, August 13, 2004 11:31 PM Subject: [Digital BW] Scanning Black & White Negatives I am new to this newsgroup & I hope this topic is correct for the group. I have gotten aware from black & white since moving to mainly digital capture. I am now attempting to re-enter producing black & white images in the digital darkroom. I am not new to digital, just to digital b&w. I currently have an Epson 2450 scanner which works "ok" for medium format transparencies. When I attempt to scan b&w negative film however, the results are horrible. Here is my two current questions. 1) How do you get good scans of b&w negative film? 2) When I scan b&w negative film and then open it in Photoshop, the file is still a negative. It has not been converted to a positive. Also, the exposure is wayyyyyy off! Always to dark, even though during the scanning process the exposure looks fine. What am I doing wrong? My work flow is: Epson 2450 scanner Viewscan 7.6.18 scan software Photoshop CS Epson 2000 printer Quadtone for Windows b&w printing software By the way, I can print b&w fine with desiderated color images. Bruce Varner Kansas City metro area Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
