RE: [Digital BW] Shadow noise in scans
2004-08-16 by Nunan, Mike
Hi Peter, I don't know if this will make you feel any better, but your findings are depressingly familiar to mine with medium speed B&W film. You hit the nail on the head when you say that a darkroom print doesn't show the same problem -- there is something happening in the interaction between the scanner and the film. Out of interest, if you compare 10x8 prints, both wet process and digital, is the digital print appreciably sharper? If so, you could soften the digital print slightly to average out the speckle and still end up with a print about as sharp as the traditionally made one. Not ideal, I know. Anyway, here's my 2p theory about what causes the problem we're both seeing. Consider the grain structure in the developed film, on a microscopic level. It consists of clouds of stringy-looking metalic silver arranged very randomly. Kodak have a shortish article about all this, including some nice photomicrograph illustrations: http://www.kodak.com/US/en/motion/students/handbook/sensitometric6.jhtml From that article: "At magnifications where the eye cannot distinguish individual particles, it resolves random groupings of these particles into denser and less dense areas. As magnification decreases, the observer progressively associates larger groups of spots as new units of graininess. The size of these compounded groups gets larger as the magnification decreases, but the amplitude (the difference in density between the darker and the lighter areas) decreases. At still lower magnifications, the graininess disappears altogether because no granular structure can be seen" Clearly each sensor site in your scanner's CCD is looking at a fairly small area. It can't resolve individual grains but it can certainly see small enough clumps that the amplitude will vary quite widely. (Referring to the article, each pixel of the sensor is behaving very much like the small aperture used to scan films when testing for RMS granularity.) I believe we are seeing this effect right across our images, but we are less concerned about it in the high and mid tone areas because in traditional processes we always see a bit of grain there. However, when we see it in the shadows, our immediate reaction is to assume it's scanner noise. In fact, when scanning negs, the signal to noise ratio should be at its best in the shadow region of the image. There are a couple of things that can help reduce the problem. We can soften the image post-scan as I suggested above, but none of us want to lose any hard won sharpness. Using a scanner with a more diffuse lightsource can make a big difference. Scanners such as Epson flatbeds do tend to give slightly softer images than dedicated film scanners, but more importantly their flat lightsources don't throw the grain structure into such sharp relief, meaning that the local variations in density are less dramatic. Sorry if this doesn't help you get better results out of the equipment you already have. I mention these issues in the hope that discussion of them will eventually lead to better solutions being found. I have seen major exhibitions of digital prints by "big name" artists where shadow speckle has been visible, so it's not just us! Best regards, -= mike =-
-----Original Message----- From: Peter A. Klein [mailto:pklein@...] Sent: 15 August 2004 10:35 To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Shadow noise in scans Folks: I frequently encounter shadow noise in my scans. I can usually work around it, but I'm wondering if there is something I can do--perhaps while scanning--to minimize it. Have a look at this: http://users.2alpha.com/~pklein/temp/noise.jpg This picture was taken with an M6TTL and CV 50/1.5 Nokton, on Kodak T400CN rated 400. It was taken in a dim reception hall, but the subjects were illuminated by a shaft of light from some nearby large windows, and I exposed for them, not the background. The scanner is a Canon FS-4000, run at 4000 dpi and driven by VueScan. I scan to 16 bit TIFF, and use Picture Window Pro in 16 bit mode for my editing. The various versions of the picture are shown at 1/3 actual pixels. The leftmost image is of the scan pretty much out of the scanner (I'd spotted and cropped, but that's all). You can see the noise in the darkest areas. This is the kind of noise I am often plagued with. It tends to happen more often in available light pictures than well- lit outdoor shots. It doesn't show much on a 5x7 quadtone print, but is quite prominent on an 8x10. And if I get the same picture printed in a wet darkroom, the noise isn't there. The center image is what I ended up with after curves, contrast, and sharpening (the latter using a mask so only the people were sharpened, not the surrounding area. I've dropped the background to nearly jet-black, but there are still lots of noise speckles. And I've lost some gradation in the girl's hair. The righthand image has been noise-filtered with NeatImage before curves, etc. I used it sparingly so it wouldn't soften or "plasticize" the image too much. It's helped, but the noise still shows up--more in a print that on the screen. I've found that most of the time, when I use NeatImage or Picture Window's Despeckle feature, I can only get rid of some of the noise before the image gets messed up. What might I try to get rid of this noise? Is there anything can I do to minimize it during the scan? I've tried the multiple exposure feature in VueScan, and it doesn't really help with this type of noise. BTW, here's the whole picture. This one is a reduction of the Costco CD Jpeg I got when the film was developed. They went way dark, so you see no shadow noise (or detail). http://users.2alpha.com/~pklein/JonAntionWedding/Show/JonAntionWedding /slide_13.jpg Thanks, --Peter Klein Seattle, WA ============================================================================== This message is for the sole use of the intended recipient. If you received this message in error please delete it and notify us. If this message was misdirected, CSFB does not waive any confidentiality or privilege. CSFB retains and monitors electronic communications sent through its network. Instructions transmitted over this system are not binding on CSFB until they are confirmed by us. Message transmission is not guaranteed to be secure. ==============================================================================
