Do Printers Only Accept 8 Bit Files?
2004-09-03 by Tom Husband
When printing a 16 bit file does the printer convert it to 8 bit?
I've been trying to get the author of Qimage to allow processing of
16 bit grayscale files.  Qimage has a feature called "print to file"
where you don't send the file to the printer but to another
location.  It's a great feature but it takes a grayscale 16 bit file
and converts it to 8 bit RGB.  Anyway, Mike Chaney has responded with
the following, "I'd also have to question why you'd want to print 16
bits/channel when printing to file because printers cannot accept
anything but 8 bit data (even when using a RIP). As far as I know,
and unless things have changed recently, all printers (the hardware
itself) are based on 8 bits/channel even when dealing with grayscale."
I was thinking that it might happen when using the Roark curves and
the Epson drivers but how about using QTR?
Tom
Re: Do Printers Only Accept 8 Bit Files?
2004-09-03 by Scott Graham
97.3% sure all printers (Epson etc) use 8 bits max.  Would be a waste to use 16 bit
considering the dynamic range of paper and ink.
I often edit in 16 bit, but convert to 8 for printing and for saving (of flattened print files).
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom Husband" <thusband@s...>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Graham"
waste to use 16 bit
> Scott
Right.  I would agree with 8 bit on the Epson driver but I'm not sure
about using QTR.
Tom
2004-09-03 by johnglodge
You original question said "printer" not driver. To get the answer
to this you need to be precise and remember what you asked.
It is quite difficult for a printer to represent 255 shades of grey
let alone anything more. Most cannot get to 255 shades of grey.
Hence 8 bit at the printer is fine and what is usual.
However because of all the layers of software in a driver or a RIP
(that might include a CMM and serious ICC transforms) there is
reason to use more than 255 so that the first limitation that occurs
is that of the printer itself and other rounding errors in the
software do not dominate.
As I recall the Windows driver and the Mac driver too are (or were)
limited to 8 bits. This is potentially a limitation whereas 8bits at
the printer is not.
...John
Graham"
> waste to use 16 bit
> > Scott
sure
> about using QTR.
> Tom
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "johnglodge"
occurs
at
> the printer is not.
> ...John
OK, I think I understand.  Thanks and sorry for not being more
precise.
Tom
RE: [Digital BW] Do Printers Only Accept 8 Bit Files?
2004-09-03 by Paul D. DeRocco
> From: Tom Husband [mailto:thusband@...]
What goes across the cable to the printer (at least for Epson) is dots, not
8-bit or 16-bit data. Standard printer drivers convert the image to dot
patterns, but only accept 8-bit data. Alternative software, like a RIP,
could in theory use all 16 bits, but I couldn't tell you if QTR does. For
B&W, it's possible that an extra bit or two might be useful on some media,
but it's doubtful that you'd see the difference for color.
Re: [Digital BW] Do Printers Only Accept 8 Bit Files?
2004-09-03 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco"
<pderocco@i...> wrote:
> > From: Tom Husband [mailto:thusband@s...]
> Paul                mailto:pderocco@i...
Both Mac and PC print systems are based on 8 bit pixel data.  So everything
that gets sent through print commands will be truncated to 8bit pixels.
I would doubt this makes any visible difference -- our eyes just can't
distinguish even 256 grays on paper.  I also think all the conversion to
printer dots is the limiting factor by far.  Another thing to consider is that
smooth areas of an image have lots of pixels and what you see is a blend
of adjacent pixels not individual pixels -- a result of dithering, ink bleed,
and eye resolution.
Roy
To be somewhat sloppy, 256 levels needs a 16x16 array of dots. Of
course that is not quite true some printers emit more than one dot
density from the jet. As well dot gain changes the result. So that
on face value at 2880 the number of halftone patches is 180 per inch
well except that the other dimension is not 2880.
If you look at the NCA greyscale for the 2200 there is a flat toe of
about 45 steps which suggests Epson is getting about 210 distinct
ink patterns and probably less. In fact I think it has to be quite a
bit less as the numbers do not compute or there are rather more jet
harmonics than I thought.
So that at the level of the printer itself 8bits is by far enough.
Even photoffset printers which were lith, ran at 2450dpi to get good
150 (I guess I will say lines)per inch quality greyscale prints.
...John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy
DeRocco"
bit?
processing of
file"
bit file
responded with
print 16
accept
know,
hardware
grayscale."
curves and
is dots, not
to dot
a RIP,
does. For
some media,
everything
pixels.
can't
conversion to
consider is that
blend
ink bleed,
> and eye resolution.
> Roy
2004-09-07 by Brad Streeter
I second that, would be great for resizing prints to send to QTR or some
other B&W print setup.
Brad
  _____
Sent: Friday, September 03, 2004 12:38 PM
Subject: Re: [Digital BW] Do Printers Only Accept 8 Bit Files?
Thanks all, I understand this better now.
Still, 8 bit grayscale grayscale capability in Qimage would be nice.
Tom
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
membership without notice.
printing. Users who persistently make off-topic posts may be removed
from the membership.
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=12909k1c6/M=296572.5305651.6444487.3001176/
D=groups/S=1705019182:HM/EXP=1094323087/A=2195326/R=2/SIG=12imrdnqa/*htt
p:/clk.atdmt.com/VON/go/yhxxxvon00700677von/direct/01/&time=109423668724
3401>
<http://view.atdmt.com/VON/view/yhxxxvon00700677von/direct/01/&time=1094
236687243401>
<http://us.adserver.yahoo.com/l?M=296572.5305651.6444487.3001176/D=group
s/S=:HM/A=2195326/rand=310897340>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
*	To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject
=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
