unclogging 1280 print heads
2004-09-10 by bbiess
I've got a new 1280 loaded with UT2 (Eboni) that I've regrettably not
used for a couple of months.  Since I've finally had the opportunity
to scan a bunch of negs, I'd now like to print them, however, all but
one of the print heads are printing VERY faintly (if at all) on the
Nozzle Check print.  I expected this would be the case and now need to
undergo a good head cleaning.
I've checked the archives for the proper way to clean my 1280's print
heads, however, I didn't find anything.  Does anyone know of a doc
that lists head cleaning instructions and techniques?
What steps should I do in what order?  Any help is greatly
appreciated!
  B2
Re: unclogging 1280 print heads
2004-09-10 by dionloy
When I got my first set of UT2 cartridges from MIS I had to run about
6-7 clean cycles. You can do it from the printer properties dialog, or
hold down the 'Ink Change' button on the printer for 3 seconds to
induce a head cleaning (the one with the black and color droplets with
down arrows above them).
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bbiess"
> appreciated!
