Re: hinge tape visible through photo
2004-09-12 by Doug I.
Phil,
I use the standard T hinge method. It's the bottom of the T that is
noticeable, as the rest is hidden behind the mat.
I prefer thicker board (front and back) which has less flex, so even
though they're only on the edges, I suspect the Nielsen springs put
enough pressure on the sandwich overall to make the relatively thick
tape eventually show through. I use glossy papers exclusively, which
I'm sure make it more noticeable.
In the future I will experiment with deeper frame channels and/or true
tissue-type hinging tape. May also be that some papers resist the
show-through better than others.
Doug
On Sep 7, 2004, at 11:53 AM,
> From: "Phil Rose" <pjrose@...>
> Subject: Re: hinge tape visible through photo (WAS: Dry Mounting Ink
> Prints - other mount
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Doug I.
> <puzzolente@s...> wrote:
>> I've noticed the hinge outline popping up too lately with the
> Lineco
>> gummed archival hinging tape. I don't think it has so much to do
> with
>> the hinging method used (well...unless you were using a really thin
>> tissue), but more to do with the really powerful spring clips that
> come
>> with the Nielsen frames I buy. They put a lot of pressure on the
>> mat/photo/glass sandwich.
> I doubt that that this can explain the "outline" problem--which I
> haven't (yet) encountered with my Lineco hinging tape. The Nielsen
> springs do exert a lot of pressure, but it's concentrated at the
> extreme edge of the sandwich. With the usual cardboard backing, this
> pressure will likely be very much diminished within the window area of
> the mat (unless your mats have _very_ narrow borders). However I
> wonder if the outline problem might be due to your method of hinging:
> do you use a "T-hinge" or a "V-hinge" method?  With the "T" method the
> hinge is taped to the backing board well _above_ the print (under the
> mat border) so that only a relatively short, single layer of tape is
> under the print. But in the "V" method, the hinge is _folded_ and so
> several layers of tape lie beneath the print, and this could increase
> the possibility of a visible outline.
> Another possible explanation for development of a tape outline could
> be if there's any differential swelling/shrinking between the print
> and tape. For example the print paper might undergo a slight overall
> expansion due to humidity changes, but this change might be prevented
> within
> the small area(s) that are tightly glued to the hinge tape. This then
> might
> produce an outline of the hinge--especially if the glue (gum) dries
> down to a rigid, glassy substance (gelatin glues do this). Of course
> the liklihood of humidity-induced dimension change depends very much
> on the paper type.
> Phil
Ditto for the Ilford Glossy, which has been the main source of my
problems. But when it happened on some Chromira and Fuji Frontier stuff
too (also glossy), I started looking more at my matting/framing system.
You may be on to something with the moisture thing....
Doug
> From: "njfranknj" <njfranknj@...>
> I've noticed the impressions of the glued linen tape on my recent
> Ilford Smooth Pearl prints, but not on older EEM or Museo papers,
> maybe due to ISP's sort of glossy surface. The ISP dents show up even
> with the relatively lower pressure, unbent, clips I've been using for
> years, but I think it is really due to the wetness of the tape when it
> goes on, which might be causing softening and expanding the paper,
> because I found it on prints that had not been framed yet, they were
> lying on my mat table for a few days with only the weight of one sheet
> of 1/8 foam core on top.
