1280 B/O printing on Red River Aurora...?
2004-09-26 by m87507
Is it possible to get a clean print using this combo? My 1280 has
MIS Ebony black and MIS orig. archival color inks on a CIS
system...this system works wonderfully w/other papers...in fact, the
B/O prints (and color) are really nice on EEM and Moab entrada, but
this Red River Aurora paper I can't get a clean sharp print...almost
like the ink doesn't want to 'take' to the paper. This is most
noticed when printing the Pantone Profiler-Plus callibration target,
not to mention regular photos that print fine on the other papers. I
really want to figure this paper out, but am stuck. Any
ideas/suggestions much appreciated..thanks(!)
Best,
Mark
Re: 1280 B/O printing on Red River Aurora...?
2004-09-27 by Clayton Jones
Hello Mark,
print...almost
Is the the same as "Aurora Art"?  I use that and get excellent BO
prints.
Are you printing on the coated side?
Clayton
2004-09-27 by m87507
Yes Clayton it is the Aurora Art...yes am printing on the coated
side, and
using a 50' roll (24" x 50'), so the paper has a curl to it going
into the printer, although that shouldn't matter...I tried the b/o
settings you suggest, which work wonderfully on the other papers,
but it just isn't 'right' on this substrate. Banding, foggy details,
slightly off of what it should be. Maybe a bad batch of paper? Is
this unheard of? Or is this just a tricky paper to work with?
<cj@c...> wrote:
> Hello Mark,
has
> the
but
> print...almost
> prints.
> Regards,
> Clayton
Hello Mark,
>side
Oh, well, so much for that.
>I tried the b/o settings you suggest, which work wonderfully on the
>other papers, but it just isn't 'right' on this substrate. Banding,
>foggy details...Maybe a bad batch of paper?
I'm at a loss for other ideas.  I suppose it could be a bad batch.
Did you see my write-up on it in the "Great Paper Chase" article?
Basically it just needs a bit of contrast boost, otherwise it's much
like other papers.
Have you tried changing the paper thickness lever to see what happens?
Clayton
