densitometer
densitometer
2004-09-30 by adie782002
I have a 404A X-RITE  corlor reflection densitometer For sale in ex.
shape . new it was $1200 I would like $500. contact me off line At
aklugman@...
densitometer
2006-03-01 by Peter Mc Mahon
Would appreciate info re Gretag DC19 densitometer.
I have not attempted profile making before, but am keen to use the QTR
programme. My usage will be moderate, so minimum cost, within reason,
would be my requirement.
 There are a large range of second hand densitometers available, all a
bit confusing. For using in conjunction with QTR, would the above
densitometer be suitable? or any other suggestions.
comments appreciated.
regards,
Peter
Re: densitometer
2006-03-01 by Helen Bach
I agree with David Tobie's comments, but if you would like a
densitometer here's my rather dense two cents.
Do you have any need for a transmission densitometer (ie for film) or
is a reflection instrument (for prints) all that you need?
Though the final image tone depends on what I find pleasing rather
than what the densitometer says, I find colour readings helpful when
deciding on changes to the ink mix when neutralising a profile. You
should bear in mind that the filters used in a densitometer were
tailored for a particular process, and they may not be entirely
suitable for other applications.
To save you searching back in the archives, here's what I wrote about
a month ago in reply to a similar question:
I'm only familiar with a few Macbeth instruments, and my experience
with densitometers is mostly in cinematography and photography rather
than printing, so this is a bit biased. I'll only mention those that
can do visual reflection measurements, because I guess that is what
you are most interested in.
The TR924 is a good all-round photo densitometer. It has both
transmission and reflection heads. It has visual (Wratten 106 filter,
amber, to mimic the spectral response of the eye), Status A and Status
M RGB channels for transmission; and visual and Status A RGB for
reflection. Status A filters are glass spectral interference
(dichroic) filters for use with prints and transparencies intended for
viewing. Status M filters are used for negative and interpositive
materials. The TR524 and TR1224 are similar. The RD919 is the
reflection-only equivalent.
The RD918 is similar to the 919, but it has Status I narrowband RGB
filters instead of Status A, in addition to the visual. I'm afraid
that I have no knowledge of Status I densitometry, other than that it
is intended for use with inks.
Addition for this time round:
Status T is a broadband filter set. Broadband filters overlap a
little, narrowband ones have gaps. They (Status T) are RGB or CMY
gelatin filters (R is a Wratten 25 or equiv, G is 61, B is 47) Most
Macbeth Status T densitometers either don't have visual filters or are
transmission only. The RD921 is a reflection-only Status T CMY
instrument that has a visual filter.
Any instrument that has gelatin filters is more likely to have faded
filters than a dichroic (interference) type. The green filter is
especially prone to fading.
Best,
Helen
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter Mc Mahon
> regards,
> Peter
