UT2 on the 2000P... a report and a request!
2004-10-13 by John Broski
Hello all, I'm a longtime lurker who has finally decided to chime in! For several months now I've been using a refurb 2000P with the UT2 inkset. (I use a continuous feed system from MIS.) I use Photoshop CS with Paul's curves for the 1280. The original curves printed too dark, so I modified them using a "calibrated eyeball"... printing lots of step wedges and comparing them to known good wedges done on my other printers. (Hint: take your best reference step wedge and punch holes in it with a paper punch. When you lay the reference wedge over an experimental one, you can easily see where errors occur.) I've used both the Eboni and PK black inks. The results on glossy paper are excellent either way. When Eboni is in the machine, I use the versions of Paul's curves which generate black from the darkest grays. A light Krylon spray will fix the tiny amount of differential gloss which appears on some papers. (My favorite paper is cheap Epson Photo Paper from Costco... just wish I had more confidence in its archival qualities... no problems so far, though.) Looks a lot like air-dried glossy fiberbase from my darkroom days. Matte printing is more problematic... I was never able to tweak the 1280 curves to my satisfaction. So I use the Epson driver with sliders and print without Photoshop curves. It works, but I miss the powerful control over print tone provided by curves. So -- Paul -- do you think some UT2 curves might be a possibility for the 2000P? Purdy please? I'm sure the FS and FSN inks are great, but I LOVE the ability to change print tone. And I have nearly-full bottles of UT2! Other notes which may help someone: 1) The BO printing from the 2000P is not good... much grittier than the BO printing on my 1270. Both are set up with Eboni, printing on Epson Matte Paper Heavyweight and Moab Entrada. The 2000 is basically unacceptable (to me) in BO mode, while the 1270 is quite good. (When the UT2's are used in the 2000, the results are much smoother than BO in the 1270, of course.) 2) I use the Russian chip reset program to reset the 2000P. It works fine for me, using Windows XP and my USB port. No need to mess with a hardware chip resetter, IMHO. See http://www.ssclg.com/epsone.shtml 3) I use MIS color inks -- the Glossy Pigments -- in the 1270, also in a CFS. This CFS cartridge has the "always full" chips from MIS, which work great. And the inks print beautifully on matte paper (with Eboni) or glossy paper (with PK). 4) To change black inks in the 1270 (to do color work on either matte or glossy), I gently pull the black line free from the cartridge itself (at the little right-angle dingus). I lift the other end out of the ink bottle and use a syringe to suck the line as clean as possible of ink. Then I slip the "other" black cartridge into the printer, reconnect the feed line onto the dingus, and insert the other end of the line into the "other" black ink bottle. This solution doesn't require "unwebbing" (separating) the black line from the other 5 lines. (And later re-attaching it with tape... ugly!) 5) I got my (color) profiles from Cathy's Profiles and I'm delighted with them. $40 and no hassles. See http://www.cathysprofiles.com/ 6) MyPublisher will produce beautiful soft- or hard-bound books of your work. Hardbound is $20 for up to 20 pages (40 images if printed double-sided, or 20 if single-sided). Format is 9 by 12 inches, with or without borders, and type effects can be added in Photoshop as desired before submitting the picture. The cover is nice linen in a choice of colors, or leather for $10 more. You prepare JPEG files and upload them to their site. I've done 3 portfolios and 3 gift books, including some really cool panoramaic images that spread across 2 facing pages. (A bit tricky... takes some planning.) See http://www.mypublisher.com/default.php And shipping (usually about $7 per book -- ouch!) is FREE in October. Finally, a huge THANK YOU to Paul, Clayton, and everyone else on the list. What a splendid resource you folks are! John Broski
