UT2 ink colors
UT2 ink colors
2004-10-23 by jgmdp1000
Is there an address where the UT2 ink colors are displayed. I have been chasing down
clogs for the past 4 days and after printing the purge pattern the first three ink positions
seem almost black from 3 different cartridges. I don't know if this is correct ; maybe I'm
just at that point of finding problems that don't exist. Is there a specific set up that one
should use when printing the purge that is different than the normal UT2 settings? Thanks
in advance.
Re: UT2 ink colors
2004-10-24 by Bob Michaels
color swatches are on the MIS website.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jgmdp1000"
been chasing down
> in advance.
Re: UT2 ink colors
2004-10-24 by jgmdp1000
That's what I thought but I had a look there and couldn't find them..is there a specific
address there where I might look?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels" <bob@b...>
> Bob Michaels
> been chasing down
> > in advance.
Re: UT2 ink colors
http://www.inksupply.com/index.cfm?source=html/colorswabs.html
<bob@b...>
> > Bob Michaels
> > been chasing down
> > > in advance.
Re: UT2 ink colors
Are you sure you don't have black rather than color selected in the
print driver? Or, maybe you just need to use a paper towel and a tiny
bit of Windex to soak up the ink from the parking pad.
Just make sure you are using dye based ink, not UT2 to try to clear
the clogs. Get the printer working clog free with dye inks, then
reintroduce the UT2.
Bob Michaels
> I have  been chasing down clogs for the past 4 days and after
printing > the purge pattern the first three ink positions seem almost
black from > 3 different cartridges.
