Scanning 6x17 (was Polaroid Sprintscan 120)
2004-10-24 by Dr Robert Young
Here "may" be an approach that will help you to solve your problem. It
depends on the hardware/characteristics of the Polaroid scanner (which
I am unfamiliar with). Whether it will help is something you will have
to determine.
I have a Coolscan 8000 with the same issue. I am thinking about getting
a 617 Fuji panoramic, but the Coolscan only goes to 6x9 ( there are
apparently 2 motor drives...one is coarse for positioning the carrier
"grossly" over a 6x19-6x20 area, the second is a fine mode that
increments over the max 6x9 area for the actual scan). I found that if
your use Vuescan software, and vary the image offset, I can get from
2-3 scans that overlap an entire  6x17 inch strip of film @ 4000dpi. I
was using a carrier that had a glass insert to flatten the film strip
and which had an "open" unobstructed area of approx 6x19.  It was
designed to allow scanning 2-neg strips of 6x9s ( or 3-neg strips of
6x6)  , or other long film strips.
The scans are done immediately after one another w/out removing the
negative carrier. I then used Photoshop CS to "stitch" the  images
automatically. It performed the job very well. The images were easy to
align (requiring adjustments in only one dimension till they overlap )
since the negative is never removed between scans. Also, the  scans are
with the same scanner settings & calibration, performed immediately
after one another, so there is no observable color shift/drifting.
Hope this gives you some ideas on attacking your problem. I'm still
saving to get the Fuji. Until then, I use an XPan.
On Oct 24, 2004, at 11:42 AM,
>>> Can onyone on the list tell me is it's possible to scan 6x17 in one
>>> pass with this scanner. I've been searching the archives but this
>>> question doesn't seem to have been asked
> No.   Not possible.   Hardware limitations prevent it.   I have 6x12
> and 6x14
> negatives that I wanted to scan on a Microtek 120tf, the
> clone/successor to
> the Sprintscan 120.   I spent a lot of time on the phone with Microtek
> and
> Polaroid both to get a straight answer.   Basically, they told me
> there are
> hardware limitations that preclude it and no software/driver solution
> will allow you
> to scan negatives that long on the machine.   Back to the flatbed!
________________________________________________________
