A new member, with a shopping list
2004-11-08 by Pieris Berreitter
I'm jumping into digital darkroom after many months of browsing this
and other forums. I hope to participate in the print exchanges but
first, I need to make sure I've got everything I need. Much of what
I've compiled here has been recommended by this forum. Is there
anything an experienced digital printer would add to this list? I
don't believe I need a colorimeter for profiling the printer as I
hope I can trust other peoples curves.
- Epson Enhanced Matte paper for experimenting
- Ilford Galerie Smooth Pearl for portfolio
(other papers will follow once I gain experience with these)
- Epson 1280 printer
- MIS UT2 inks
- Lascaux Fixative spray
- Colorvision Spyder with Photocal
- Solux 4700K lamp for proofing (I'll be working at night)
- Photoshop CS
- Logan 450 Mat Cutter, mats, and tape
- flat print boxes for storage
- Big tupperware box to cover printer when not in use (I will throw a
wet sponge in here as well to keep the heads happy)
Do I need anything else? A head cleaning cartridge?
-Pieris
Re: [Digital BW] A new member, with a shopping list
2004-11-08 by Hans Van Rafelghem
The Smooth series are fastdrying and more used on the 2200, I think the
1280 can use Classic series also.
Make sure you have the new version 2
Seems overkill to me, never had problems with that. Maybe if you have a
very dry house.
A camera?
Hans Van Rafelghem
http://www.vanrafelghem.com
Re: A new member, with a shopping list
2004-11-08 by Bob Michaels
I've been printing for several years with just:
1) Computer w/ Photoshop
2( Printer (OK I have two)
3) Ink
4) Paper (several kinds)
But I don't think I have anything else on your list. Never missed any
of it.
I suggest you save your money to buy more film, paper and ink. Then
shoot and print more.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Pieris
> - MIS UT2 inks
> - Photoshop CS
> Regards,
> -Pieris
RE: [Digital BW] A new member, with a shopping list
2004-11-08 by Paul D. DeRocco
> From: Pieris Berreitter [mailto:pieris@...]
> - MIS UT2 inks
> - Photoshop CS
You don't describe your computer setup. How much RAM and disk? Tons of RAM
can be very useful, and saving raw images or big TIFF scans can eat up disk
space pretty fast.
Over time, you may encounter little software add-ons that prove useful, for
B&W conversion or page layout, but you can do everything you need with PS
CS. However, you didn't say how you're getting your images into digital
form. If you're shooting digital, you may want to look into alternative raw
converters like CaptureOne. (Personally, I like the PS converter, but others
swear by C1.) If you're shooting film, then the scanner becomes the can of
worms.
Possible overkill: I'm not sure the spray is important, but I guess it's
pretty cheap. If working only in B&W, the color temp of the room lighting
isn't that important, since you're not judging color, only tone.
Tupperware box and sponge? That's a new one. Do you live in the desert?
2004-11-08 by Paul Roark
>I think the 1280 can use Classic series also.
For the UT or other pigments, don't use the Classic series.
Related to glossy paper, the PremierArt Print Shield does a better job of
hiding the bronzing than Lascaux.  The Lascaux is better on matte paper,
where it doesn't reduce the dmax significantly, which PremierArt might do.
You probably could also get away with less hardware.  For example, I
recently used a Spyder2PRO for profiling my monitor.  I'm sure it's great
for color, but for B&W, the Adobe Gamma routine is just fine.
Good luck with your B&W.
> From: Paul Roark [mailto:paul.roark@...]
Adobe Gamma relies upon you monitor having a knob that adjusts the black
point, which LCDs don't generally have. With a CRT, though, it's probably
enough.
2004-11-09 by Pieris Berreitter
Thanks very much for all the responses.
Paul Roark,
You're probably right about the spyder not being obligatory, but I've
been using Adobe Gamma for a while and have had problems with labs
giving me poor images and then blaming my profiling scheme. I also
need to be able to match the scanner/printer to a different PC if
need be.
Paul DeRocco,
If anything, I might need more RAM, but I think my 512MB/200GB system
will suffice for now. This is something that at least will not have
an effect on quality (just productivity).
Bob,
It's true that this might seem over the top for an intro system, but
my needs are rather specific and I need a system that will work on
multiple computers (hence the profiler) and I will be transporting
prints around quite often (hence the fixative and matting equipment
for print longevity).
A few people asked about my apparently novel idea of a sponge in a
box. I actually found this tip online somewhere, and it's because of
my prior experience with Epson printers that I'm concerned about head
clogging. I understand that it's necessary to print about twice per
week to prevent clogging. My workroom does have very low humidity.
-Pieris
this
> - MIS UT2 inks
> - Photoshop CS
a
> Regards,
> -Pieris
2004-11-09 by Christer Rosewelll
Pieris,
you're doing well with this list... Seems you've done some serious
thinking and you're definitely going about it the right way.
Someone - or more - may tell you you do not need to spend money on a
calibration unit - don't listen to them!
To be able to color match what you see to what you get is absolutely
imperative - if you can't trust what you see on your monitor - when
soft proofing - there's just no way you're going to be happy with the
result..
Myself I am a Monaco man - Monaco Optix XL Pro and EasyColor - with it
I calibrate every paper I use and all my monitors - including my
Powerbooks - and when I print, what I see is what I get - never any
guesses or wasted paper, ink and time - and if I need to send anything
out, I know my printer is also color calibrated so no problem there -
when he's done printing my files I know they are correct.. Big peace of
mind...=*^)
I guess the only thing you did not mention was a computer but smart as
I am I figure you got at least one,,,=*^)
Good luck!
Christer
			Christer, AKA Christer Rosewell
"It's the artist's job to accomplish two things-to stir the emotions of
the viewer
	  and to lay bare the soul of his subject." Jousuf Karsh
      Member EP (Editorial Photographers) - 4,000+ professionals
worldwide.
			  http://www.ChristerArt.com
		  	   3.4+ million visitors to date..
On Nov 9, 2004, at 12:48 AM,
> From: "Pieris Berreitter" <pieris@...>
> Subject: A new member, with a shopping list
> - MIS UT2 inks
> - Photoshop CS
> Regards,
> -Pieris
