Another crack at ImagePrint versus StudioPrint
2004-11-13 by jay@ariseditions.com
I like a number of other folks am trying to decide between
ImagePrint and StudioPrint. The one missing piece of info for me is
how well StudioPrint is able to produce neutral B&W prints using the
Ultrachrome inks. There is consistent positive feedback on
ImagePrint about it's ability to handle B&W as well as superior
quality on color images. I hear good things about StudioPrint when
it comes to print quality but it's very hard to find a good print
quality comparison between ImagePrint and StudioPrint from a
hardcore hard-to-please observer.
I'd love to hear from anyone that has done or seen any kind of side-
by-side comparison or has any experience printing B&W with
StudioPrint using Ultrachrome inks.
-J-
http://www.ariseditions.com
Re: Another crack at ImagePrint versus StudioPrint
2004-11-13 by Tyler Boley
I am testing a StudioPrint apraoch to B&W with Ultrachromes now. But I
won't be done, and able to report, for a few days at the least. Since
I don't have IP a side by side won't be possible here.
Tyler
> -J-
2004-11-14 by john dean
You know Tyler, this is exactly what a lot of us out here are more than curious about. The
talk in the past was that you couldn't do tone chanel linerizaton as well with Studio Print,
right? That's why you bought a PC in ther first place to use Imageprint with quads?
It seems that with ultrachromes the first thing you want to do is shut off the yellow
channel, which is the pigment most likely to fade and cause metamerism, right? Then what
happens?, you desaturate the other color channels and balance them out?, or cut them off
altogether and print out ot two black channels?
I just suggested the QTR rip for a friend with a 2200 and he was very happy with the
neutral monochromes that he is now getting to use in his ad book. I want to see those
this week.
It seems to me a decent rip along with a printer specific profile curve might be the answer
for using ultrachrome for serious work. I guess that is what Nash Editions is doing
John
> Tyler
I'm sorry, I meant you were using Studio Print with a pc.
The bottom line is - which RIP of them all is superior for making monochrome profiles
with ultrachrome inks. About the time someone figures that all out, Epson will come up
with some bullshit quad set, and act like they invented it. Regardless, I believe you should
be able to make some pretty decently neutral prints with the 4000 and a good rip.
2004-11-14 by Tyler Boley
Absolutely the reverse. I use StudioPrint. Linearization ability is
great, no matter how you assign ink tanks to channels, including quads.
shut off the yellow
metamerism, right?
That seems to be a bit of a list myth. Yellow is used least if any,
for the neutral to cold options because it's not needed, since the UC
K and light K inks are warm to begin with and used all the way up the
scale. If you want warmer than UC Ks can do, yellow is introduced.
Carl posted some info that showed the C and M inks actually more
metameric than the yellow.
There are any number of ways to do this, but if you want warmer
tinting ability, you will not turn Y off even though you may limit it
a lot. It simply won't be used unless necessary.
> Then what
Assuming you have StudioPrint's control, you may limit the color inks,
or use the light components only. Additionally you may also limit
them. It depends on how much toning ability you want.
very happy with the
want to see those
> this week.
Editions is doing
The last Nash B&W prints I saw were clearly normal color UC prints
with good profiles for neutrality. That may have changed more recently.
Even with the above scenario, good (and specifically made) profiles
will be necessary. The advantage of QTR is that a light K to K split
can be done, and then specific amounts of "toner" inks can be added
for neutrality or tinting, then the whole thing linearized overall.
With a RIP like StudioPrint, final neutrality and gradation has to be
accomplished with a profile made with carefully selected K generation
and ink limit. So far here, it's trial and error.
By the way, my understanding is that the new version of StudioPrint
comes with pre configured environments for this very purpose. I know
they nailed it some time ago, it's not that hard if you have the
knowledge and toys they have.
Tyler
> ... I believe you should
and a good rip.
See this post-
http://groups.yahoo.com/group/EpsonWideFormat/message/52909
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> Tyler
Or ImagePrint, or Colorburst, or...
Attempting to be PC is such a burden.
Tyler
2004-11-17 by jay@ariseditions.com
Hi Tyler, I was wondering if you've made any progress on B&W prints
with StudioPrint and Ultrachromes <g>.
-J-
But I
[snip...]
2004-11-17 by Tyler Boley
Not quite there yet with v10, been too busy. v11 demo on the way which
should be better anyway.
Tyler
> -J-
> But I
> [snip...]
