Tony Bonnano reply
2004-11-20 by claudej1@aol.com
Although I also have Nikon glass, as a "Canon guy" going back to the Kodak 520/Canon 2000 ($15,000 for 2 megapixels, how soon we forget), I have been through the evolution of TTL flash. As a general practitioner, Weddings are a small part of my repertoire. I currently have the 1D Mark II and the 20d, upgraded to these as they became chronologically available simply because of ETTL-2. It will NOT blow out the whites like the 10d or 1d did, which is death in digital capture. I can easily fix a shot that's up to 2 stops under. I actually use those cameras at the Medium jepeg fine setting, which is a 4 Megapixel file. Anything more than this on a Wedding is overkill for an 8x10 or smaller print and this file will easily print a 16x24 on a 7600. So you can look at a 1Ds mark 2 as having a 4x oversampling characteristic in capture. Downshifting in the camera will increase the pixel quality because is samples 4 native pixels ahead of color interpolation and downsampling. It wil also have a better selective focus characteristic, for obvious reasons. On the issue of the R800, that unit is a fantastic color printer and does an "acceptable" job on B&W, but you CANNOT use it in BO mode. I own lots of Epson and have had every major unit since the original Stylus in 1994, and this is the first one that does this. I have yet to see a better color output than the R800 from any printer including the 4000, which does a fantastic job on BO, posted a few days ago.........no comments or replies. Claude Jodoin Tech. Editor, Rangefinder [Non-text portions of this message have been removed]
