Remove bronzing
Remove bronzing
2004-12-13 by bjornaagedk
Is there any spray or coating that can remove the bronzing that occurs when
printing with Epson 2200 on some pearl or glossy papers?
Re: [Digital BW] Remove bronzing
2004-12-13 by Steve Schaefer
> I use Premier Art Print Shield. It helps a little with the dmax, It enhances
> the UV light resistance to fading and helps to hides the bronzing. The only
> problem with it is that you definitely have to use a respirator or have the
> room well vented or both.
> Steve
2004-12-13 by Chris Hargens
Just how much does Print Shield hide the bronzing? I came across this
website --
http://www.artphoto.co.nz/varnish/links.htm
that has a list of products for coating inkjet prints, including
pigmented inks. In particular the Breathing Color product seems
attractive because it is water-based and doesn't give off any
hazardous fumes. I'm not sure, however, if it is effective in
reducing bronzing on glossy or pearl papers.
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Schaefer
It enhances
bronzing. The only
or have the
> > Steve
occurs when
> I just finished printing a series of 16x24 photographs, which I printed on
> Epson Luster and sprayed with Premier Art Print Shield.
> I showed the prints to a group of photographers who where surprised to find
> out that they were digital prints.  I think the Premier Art Print Shield
> masked the bronzing problem completely. Along with added dMax, UV protection
> and more depth you get from your prints I think Premier Art Print Shield is a
> very good product. although, if I could find something that work almost as
> well and was water-based I would use it.
> If you decide to try the Breathing Color product please let me know what you
> think.
> Steve
> website --
> Chris Hargens
> It enhances
> bronzing. The only
> or have the
>>> > > Steve
Re: Remove bronzing
At some point I'll probably try the Breathing Color coating --
especially if they offer a sampler size. Right now I'm going to go
with the Print Shield and try it on InkJetArt's Micro Ceramic Gloss
Plus. I may also give MIS' GLOP a try at some point. Thanks for the
information.
Chris Hargens
printed on
surprised to find
Shield
protection
Shield is a
almost as
know what you
> > think.
> > Steve
