Setting Monitor Luminance, Col Temp & Gamma
2004-12-18 by frankg_photo
When calibrating a crt monitor (I guess a lcd is different?) on a PC
running windows what settings should be used. According to computer-
darkroom/Ian Lyons, using OptiCal the Luminance white & black points
are set to .3 and 90. The col temp to 6500K and the Gamma for a PC 2.2
Could the col temp be set at 5000K which I think is more of an
industry standard. I think that prints should be viewed under the
same light temperature as the monitor is set to?
For PC 's is the gamma standard 2.2 ? And for Macs 1.8 ?
What if I need to work with someone (provide files) who is printing
from a mac, should my pc be set to 1.8 too or will the
platforms 'talk to each other' if I'm on 2.2 and he is on 1.8 ?
And the white and black luminance points  .3 and 90 that are
recommended..are these standards or ....???
thanks
thanks
Re: [Digital BW] Setting Monitor Luminance, Col Temp & Gamma
2004-12-18 by Stephen Petegorsky
On the subject of white point settings, I use 5000 K for the reason you
mentioned - that it is an industry standard for viewing.  I often have to
make files and prints that match slides, transparencies, or original
artwork, and have a GTI Softview viewer near my computer that allows me to
either use 5000 K reflected light or 5000 K light from behind to see
slides/film.  Many people seem to choose 6500 K because they feel it is
brighter and not that much different, but I find for critical purposes my
setup serves me well.  I'll be curious to see what the reasons are for other
choices!
P.S. - Obviously if you are making a print that will be seen under something
other than 5000 K light, you need to have a profile, curve, or make some
adjustments that take the final color temperature of that light into
account.  But to use the 5000 K matching as a starting point gives me a base
file that I can tailor to other uses, if necessary.
RE: [Digital BW] Setting Monitor Luminance, Col Temp & Gamma
2004-12-18 by Paul D. DeRocco
> From: frankg_photo [mailto:fh.gross@...]
Some people swear by 6500K, even though their viewing lamps are closer to
5000K. Personally, I like having them match. I use Solux halogens, and have
tweaked the line voltage with a variac to get 5000K at the viewing surface,
measured with an Eye-One, and the match between that and my CRT is
excellent.
The whole point of profiles is that it doesn't matter how you calibrate your
monitor. The monitor settings only affects non-color-managed stuff in
Windows, like Internet Explorer, your wallpaper, and the window borders. The
Mac, as I understand it, is completely color-managed, so the profile will
provide the correct appearance even in web browsers.
I like getting the monitor as bright as I can, but my monitor's power
supplies are a bit weak. If I crank the brightness (actually the Contrast
knob) all the way, the power supply sags depending upon how much white is on
the screen, which makes it totally impossible to calibrate the monitor. So
what I do is put up a black background, then put a small white square on the
corner of it (you can use Photoshop or Paint). Then, I opened up a Notepad
window to fill most of the screen with white, but leaving the white square
uncovered. Then, I watched the small white square while I alternately
minimized and restored the Notepad window, to see if the white square
changed in brightness, meaning the power supply was sagging. I adjusted the
monitor's Contrast knob as bright as I could before this effect became
visible. Then, I used my cal software to measure the brightness, and used
that as my white luminance for calibration purposes. Of course, you may have
a monitor that you can crank all the way up with no problems. I've never
heard of anyone complaining about a monitor that's too bright, but I suppose
such a thing is possible, in a dark room.
As to black luminance, I like setting it about as low as the monitor will
go, but 0.3 sounds pretty reasonable.
Re: Setting Monitor Luminance, Col Temp & Gamma
2004-12-19 by bruce greene
A Variac is a big light dimmer. A large variable resistor. They come in
many different sizes depending upon the amount of electricity used.
As more resistance is applied, the voltage to the lamp drops and the
light output decreases while the color temp also decreases.
By the use of the dimmer, I assume that the Solux halogens are filtered
in such a way as to produce light (at normal voltage) of above 5000K.
On Sunday, Dec 19, 2004, at 08:43 US/Pacific,
> Message: 18
>    Date: Sun, 19 Dec 2004 08:36:04 -0500
>    From: Stephen Petegorsky <petegorsky@...>
> Subject: Re: Setting Monitor Luminance, Col Temp & Gamma
>> surface
> Paul - What's a variac?  How much tweaking can be accomplished with it?
2004-12-20 by Pieris Berreitter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Stephen
viewing surface
it?
Running the solexes at the voltage required to get 5000K (about
13.2V) would reduce life significantly (by more than half)... but
what I'm interested in knowing is what kind of fixture you are using.
I am considering building something given the high cost of the retail
fixtures.
-Pieris
RE: [Digital BW] Re: Setting Monitor Luminance, Col Temp & Gamma
2004-12-21 by Paul D. DeRocco
> From: bruce greene [mailto:bagreene@...]
Actually, it's a variable transformer, which has a range that allows for
some step-up, not just dimming. Since the fixtures are Chinese, they are
designed for 125V, and the bulbs were running well below 5000K without the
variac.
> From: Pieris Berreitter [mailto:pieris@...]
> fixtures.
Some crappy Chinese track lighting, with high-frequency switching
down-converters built into each fixture. I don't have the boxes any more,
but the fixtures themselves say WAC on them, whoever that is. Works fine,
though.
However, you won't get 5000K unless you can step the voltage up a little. I
just happened to have an old variable transformer lying around, so I used
it.
RE: Re: Setting Monitor Luminance, Col Temp & Gamma
2004-12-22 by bruce greene
Thanks Paul,
I seem to remember burning out bulbs quickly by applying extra voltage
to get a little bluer light.
It's been a while since I handled one myself...
-bruce
On Tuesday, Dec 21, 2004, at 07:43 US/Pacific,
> Message: 8
>    Date: Mon, 20 Dec 2004 20:34:15 -0800
>    From: "Paul D. DeRocco" <pderocco@...>
> Subject: RE: Re: Setting Monitor Luminance, Col Temp & Gamma
>> in
>> filtered
> for
> are
> the
> variac.
