Old salesman's credo
2004-12-18 by claudej1@aol.com
In a message dated 12/17/2004 8:49:22 AM Pacific Standard Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
Misinformation is worse than ignorance. I honestly don't want to sound like a
naysayer here, but I worked as a beta tester/consultant with Foveon and have
a direct line to their chief engineer. Most of what is written is based an the
old salesman's credo "BS spoken with conviction sounds better than the
truth."  I hate to see this kind of stuff on any forum and I challenge the writer to
respond with facts instead of sweet sounding opinions.
I INSERTED MY RESPONSE IN CAPS, SO I'M NOT SHOUTING.
Claude
(There are about 50% more green sensors than those filtered for red
> and blue, once again to provide more luma information.)
THERE ARE TWICE AS MANY GREEN SENSOR ON A NON-FOVEON BAYER ARRAY SENSOR, NOT
HALF AS MANY. DON'T MAKE THIS KIND OF ERROR ON MY PAYCHECK OR TAX RETURN. THE
FOVEON HAS ALWAYS HAD THE SAME NUMBER OF SENSORS FOR ALL 3 COLORS.
> Luma is just brightness. It has nothing to do with sharpness. ALL the
> sensors are responding to luma, but each in only one portion of the
> spectrum.
HAS EVERYTHING TO SO WITH MODULATION THEREOF BY THE LENS USING DIFFERENT
COLOR ILLUMINANCE AND REFLECTANCE, SO IT HAS A GREAT DEAL TO DO WITH IT.
> AntiAliasing is a "cure" to color issues, and has nothing (much) to do
> with luma. The anti-aliasing filter may be physical (which can lend to
> softness issues that can be severe, and easily discernable,  or it
> calculated, which produces information depending on how well done the
> algorythms are, and the layout of the sensors.)
> The need for anti-aliasing comes from trying to deal with a
> sensor-group which has two different colors meeting in a sharp line
> across it.
ANTI ALIASING FILTERS HAVE NO COLOR BIAS, THEY ARE SIMPLY A LOWPASS FILTER
AND ARE ABSOUTELY CALCULATED IN CONCERT WITH COLOR SMEARING ALGORTITHMS IN THE
DIGITAL SIGNAL PROCESSORS OF THE SYSTEM. THE SYMPTOMS OF THEIR ABSENCE ON BAYER
FILTER ARRAYS ARE VISUALLY MANIFESTED IN COLOR, BUT THEY ARE NOT A COLOR
ISSUE PER SE.
> Thus, if you shoot camera RAW, and select one channel, (any channel)
> you'll get perfectly sharp information,  since a pixel in is a pixel out.
> True: the Foveon does not require color anti-aliasing, but that has
> nothing to do with single pixel sharpness.
THE FOVEON ONLY SHOOTS RAW AND HAS EVERYTHING TO DO WITH SINGLE PIXEL
SHARPNESS. WHERE DID YOU GET THIS BS WHEN TALKING ABOUT BAYER ARRAYS? WHAT IS
PERFECTLY SHARP? 1/4 OF THE ARRAY PIXEL COUNT? WHAT PICTCH? WHAT FILTER?
> However, all that said, simply take a RAW camera image (say 3024 x
> 2024, as it comes from the S2 pro) and select split channels in Photoshop.
> You'll get three images with different ranges of gray tones, depending
> on the range implicit in the color filter. Each image will be some
> range of "black and white" and each image will be exactly 3024 x 2024,
> and contain just over 6 million pixels... not 1.5 million.
THIS IS AFTER FUJI DOES THEIR SQUARE ROOT OF TWO, OCTAGONAL TO ORTHOGONAL
VOODOO MATH, SO IT'S PROCESSED INFORMATION WHICH IS 5/6 INTERPOLATED AND NOT
NATIVE DATA.
> I have no idea what "real sharpness" is, but, in terms of raw pixels,
> and raw data, from a Camera RAW file,  the 6 megapixel image IS twice
> as dense as the 3, and thus provides twice the information to deal
> with, and has, hence twice the resolution.
IT'S NOT THAT SIMPLE.
> Take a camera RAW of 6 megs, and blend the three layers to your liking
> for full tonal range, and you'll have a perfectly sharp 6 meg photo.
YOU ARE STILL TALKING A PROCESSED IMAGE NOT RAW, UNLESS IT''S FOVEON WHICH IS
RAW. BTW, I HAVE OWNED 4 DIFFERENT FOVEONS CAMERAS FOR 5 YEARS AND PRINTED
MANY IMAGES FROM THEM, B&W AND COLOR.
> Take the color information out of a 3.5 meg photo, blend the results,
> and you'll still have  3.5 megs of resolution.
COMPARED TO WHAT? NOT ALL PIXELS ARE CREATED EQUAL AND FOVEON PIXELS ARE
ROUGHLY THE SAME AS TWICE AS MANY BAYER PIXELS IN THE FILE.
> Remember, we're talking B&W here, not color, which is what
> anti-aliasing is used for...
THE SYMPTOMS OF ALIASING SHOW UP IN COLOR THE MOST, BUT AA FILTERS ARE NOT AS
COLOR DEPENDENT AS YOU SUGGEST. THE COLOR DEPENDENCY OF THE
LUMINANCE/ILLUMINANCE IS SMALL FRACTION OF THEIR TOTAL EFFECT.
> And it is impossible for there to be such a thing as an "interpolated'
> RAW file: either it is RAW info, or it is interpolated info, but it
> cannot be both, by definition. RAW is what the CCD photo sensors put
> out: period. (I understand the confusion, the tyranny of words, that
> can arise, since the Foveon only puts out a "raw" file, but to keep
> the terminology correct, once that file is interpolated, it is no
> longer "raw" in the sense normally used when speaking of digital
> camera RAW files.
ARE YOU TALKING ABOUT COLOR INTERPOLATION? FOVEON DOES NOT COLOR INTERPOLATE,
EVER. TYRANNY INDEED.
> Yes, the Foveon is great, particularly for color. Excellent stuff. But
> there is a trade-off on sheer resolution vs the lack of need for
> anti-aliasing. Bottom line, for color, is how you like the result.
> It's the photo, stupid!  :-)
THIS IS THE ONLY TRUE STATEMENT YOU HAVE MADE SO FAR. JUST LUCKY I GUESS.
> But for B&W, if using RAW files, then there is no anti-aliasing, and
> no matter how you slice the pie, 3.5 megs is less information than 6.1.
FOVEON RAW FILES HAVE HISTORICALLY BEEN 12 MEGAPIXELS, 16 MEGAPIXELS (ON
THEIR MONOCHROME SENSOR, NEVER PRODUCED) OR 10.5 MEGAPIXELS ON THEIR CURRENT X3
CHIPS. THEY HAVE NEVER BEEN 3.5 IN RAW. THEY ARE 4.5 ON THEIR SMALLEST CHIP, NOT
YET IN PRODUCTION CAMERAS, BUT FORTHCOMING IN POLAROID CAMERAS, IT WOULD
SEEM.
Re: [Digital BW] Old salesman's credo
2004-12-18 by Tom Baker
Thanks Claude.  Interesting stuff.
Tom Baker
Claude
> spectrum.
> across it.
ISSUE PER SE.
NATIVE DATA.
> camera RAW files.
SEEM.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
Conviction and shouting...
2004-12-19 by koloshor
Agreed...
There is some minor misinformation, and some major misinformation in your replies, so I'll address that, but not in all caps. Despite your disclaimer, it is shouting. And, from a human perceptual viewpoint, it slows down the information flow, considerably.
> HALF AS MANY.
He didn't say "half as many". That's what "more" means. Now, it would have been better if he had gotten the number right, and said "100% more" or "twice as many", or if he had simply left the number off and said "more". But he never said "half", which is not more.
Yes, but not the same resolution, because of diffusion. This most strongly affects the red layer, hence the need for red sharpening in the raw processing algorithms.
Have a look at an SD9 or SD10 raw file in "medium" resolution. The horizontal and vertical pixel counts aren't even multiples of the sensor's pixel pitch (like they are in "low" resolution) so the Foveon VPS (pixel binning) isn't what produces the medium resolution. It's (gasp) interpolated.
> > camera RAW files.
Actually, it does interpolate, and quite elaboratly. There have been some excellent technical papers by scientists at Foveon and HanVision (a maker of industrial cameras using Foveon sensors) explaining how the output of the Foveon sensor isn't colormetric, and conventional processing (such as the linear 3x3 matrix transforms) used with Bayer filter or sequential color filter cameras produces color errors. Therefore color interpolation (such as the 3-space to 3-space interpolation used in ICC profiles) is applied to increase color accuracy.
The SPP software also appears to lean quite heavily on other color interpolation techniques such as memory color recognition.
You're really not doing all that well, yourself.
> SEEM.
Pixels (outside the world of Foveon marketing literature) are spatial. The X3 sensor has 3.4 of them. It doesn't matter if you sample 1 color, 3 colors, or 31 colors at each pixel, it's still a pixel. I enjoy working with Foveon cameras, but their attempted redefinition of the term "pixel" is, as far as I'm concerned, an excellent example of your old salesman's credo "BS spoken with conviction sounds better than the truth."
p.s. it's actually a political observation, typically referred to as the doctrine of "the big lie", not a salesperson's credo.
"Nothing overshadows truth so much as authority."
                      ---Leon Battista Alberti
"Tell a lie loud enough and long enough and people will believe it."
            --- frequently attributed to Adolph Hitler, sometimes to Joseph Goebbels, probably spuriously in both cases.
2004-12-19 by Ernst Dinkla
> NATIVE DATA.
Claude,
Some tests on dpreview show that the new Fuji sensor has some
advantages. The 6 MP of the E510 is roughly equivalent to the 7-8
MP of the more traditional Bayer lay-outs of similar size. That
Fuji new sensor lay-out is more related to a kind of multi
sampling than to higher resolution as a result of the lay-out. At
least that's what I think happens. Signal/noise being better.
I've never seen discussed the relation between 45 degrees
halftone screens in monochrome printing and the original Fuji
sensor lay-out.  The 45 d angle of the halftone screen is far
less "visible" than when the same resolution screen is used at 0
degree. Same information with less artifacts. For many scenes the
Fuji sensor should be less prone to moire creation too. That the
45 degrees angle of the sensor wells isn't there anymore in the
displayed image is another matter, I wonder whether the eye >
brain translation isn't in line with the Fuji interpolation
algorithms to a higher resolution.
Fuji's claims are exaggerated but there's some gain there. I do
not have Fuji cameras :-)
Ernst
2004-12-19 by tvalleau
NOT
> HALF AS MANY.
Oh my goodness. Please read more carefully. 50% (ahem) MORE I said, not less. I'm
-talking-about the bayer type.
> > spectrum.
I'll confess I have not got a clue what you're saying here. I'd be pleased to learn how
-sharpness- at any single given photo-site even exists, much less what a colored filter
above the site has to do with it. All that is happening is that some portion of the spectrum
is filtered out as the light-level is converted to electricity by the sensor. True, a full
spectrum appears "brighter" to the human eye (and the sensor) than a single color will, but
it's still just a luma value that is being recorded... And I'll continue to maintain that
brightness is not sharpness.
> > across it.
IN THE
BAYER
> ISSUE PER SE.
Exactly what I said: sensors are strictly luma information. They do not respond to color,
except as determined by the RGB filter over them.
all cameras "shoot raw"....whether record the file RAW or allow further in-camera
processing is an option with other cameras, but not the Foveon.
IS
Please read carefully.... my entire -point- is that without the use of antil-aliasing,
sharpness remains. "if you shoot RAW, you'll get perfectly sharp information..." Please see
comments below.
And, as I noted, I was trying to figure that out that 'sharpness' phrase having been used in
a previous post. Sharpness, I suggest, has to do with resolution. To take a "reducto
absurdum" example, imaging a photo of a human face made with 10 pixels vs one made
with 6 million pixels.
NOT
> NATIVE DATA.
As far as I know, (and at least on the Fuji), this is not true. The raw camera luma values
from the sensor sites is saved. I believe that color interpolation only occurs if one chooses
any of the other non-raw formats for saving (such as TIFF, or JPEG).
I'm afraid you're confusing resolution with color information. A Pixel is a single picture
element, comprised of r,g,& b information in three channels. The Forveon advantage is
that it directly reads all that information from a single photo sensor site, while a Bayer
array interpolates the site information across approximately 2/3 of the sensor locations
when the information is processed. It needs to be processed, of course, because the color
filters are side by side instead of stacked. The Foveon method is vastly superior to Bayer
on a photosite by photosite basis, since there is no need for interpolation. But a PIXEL is a
pixel is a pixel.  It's only when you start putting anti-aliased pixels side by side, in groups
larger than one, that the problems with false colors begins to show up.
AS
You may be correct, but that is not how I understand it. The luma information in a file is
approximated 1000 times greater than the color information. However, we may be talking
with different words here again.
> > camera RAW files.
INTERPOLATE,
"interpolated raw" was not my phrase: I was responding to what was said in another post
and I was correcting it to reflect what you're saying.
So, please, please -read what I said-. That is -exactly- what I said. The Foveon does not
need interpolation.
An unnecessary dig when all that is apparently happening is a failure to understand the
terminology used (file size versus sensor sites).
CURRENT X3
NOT
> SEEM.
Interesting. In their ad for the SD10, appearing in Shutterbug, page 21, Jan 05 , they say
"3.4 red, 3.4 blue, 3.4 green". That would be, as I understand their technology, a CCD
array of 3.4 million sensors sites, with pure red, green and blue data from each one.
The point you are missing is that I was describing sensor sites, receptors, since we were
discussing how the Bayer interpolation works, which is only meaningful if you're talking
about sensor sites. The Foveon has 3.4 million. Other, non- stacked arrays have 6,
8,12 16, or (as with Leafs) 22 million or more sensor sites.)
My only point is that the Foveon 3.4 (I misspoke when I said 3.5) sensor sites to work with.
That is less than 6 million sensor sites.
Sounds to me like you're confusing file size with pixel resolution. A Pixel, "picture
element" is the smallest 'dot' you'll see on the screen. It is composted of R, B and B
information.
Your camera has sensor sites. The Fuji, for example has 6.1 million sensor sites. The
Foveon has 3.4 million sensor sites. That is the native resolution of the camera.
 I was pointing out that 6 million pixels (even if you're not a big fan of how the color in
each site was arrived at) is a higher resolution than 3.4, and that there is trade-off
between what the human eye will see in a photo made of 3.4 million pixels, and one made
with 6, 8, or 12 million pixels.
I apologize if I was not clear enough in separating out the discussion as to sensor sites/
pixels and file size. I assumed that since we were discussing anti-aliasing, and "sharpness"
that we all understood we were talking about pixels and not file size.
You are perfectly correct that the Foveon puts out 3.4 million bits of raw, uninterpolated
information for red, green and blue. A 6 megapixel camera directly reads 1.5 megs of
"pure" red data, and interpolates the remaining 4.5 million megapixels; ditto for blue, and
3 megapixels of green with the other 3 interpolated.
All added up, that is 6 megabytes of information in 6 megaPIXELS .
Add up all the Foveon colors and you'll get 10.2 megabytes of information, in 3.4
megaPIXELS.
I should also note that I've got back to the technical documents, and must correct myself:
the CCD in the Fuji -does- have a low pass filter on it (along with an infra-red).
I am sorry that this exchange deteriorated to such an extent.
May I only suggest that one -carefully- read posts, as I'm sure that doing so, and using
words with mutually agreed-upon meanings will improve the quality of communications.
Cordially
Tracy
2004-12-19 by Andre
information, in 3.4
> megaPIXELS.
I must say that I could not care less about technical details such as
these. Don't get me wrong, I'll defend your rights to voice your
opinions and I'm sure it make for interesting post for those tech.
inclined.
It does not matter to me if it's got a Bayer something or not, if it's
3.4, 6, 8 mp. What I do care about is if I will see a difference in a
print for a given size. To me, the proof is in the print.
So, will it allow me to print the image at the size I want, is the
build quality acceptable and is it within budget constraint and price
competetive.
Sorry about the interference. Please resume your discussion.
Andre
Got to agree with you 100% !   That's why I said (in a previous post) "It's the picture,
stupid!"  :-)
OH... as to my "50% more"  some of you will recognize "retail markup" there... was always
confused with "retail down, or cost up"... It's been 40 years since I worked my way through
college in the rag-trade, but the convention of "retail down" stuck...
Cordially,
Tracy
