This is a good question, that I wish I had asked when I first
archived some partially used ink cartridges.
Basically there are two issues you need to deal with
1) Evaporation (which is obvious) and,
2) Bacteria growth (which, at least for me, wasnt initially obvious)
You can slow evaporation by sealing a cartridge in a well evacuated
plastic bag, but, this will not prevent bateria from growing within
the ink itself. If bacteria forms, you'll be able to tell because
the ink will become *stringy* (which is actually the bacteria!). You
can slow the growth in several ways: placing it in a well evacuated
plastic bag, seal all the ports on the cartridges and put in a cool
place (think of it as a piece of meat - but DONT freeze it!). This
could keep a cartridge for up to a year (I've done it with ok
success), but its not guaranteed, and different inks are prone to
bacteria growth at different rates. You can also try to *seal* the
cartridge in a food storage vacuum sealer (for instance something
like http://www.cooking.com/products/shprodde.asp?SKU=302042) ,
which, in theory, will slow evaporation and bacteria better than
just a platic bag. Of course, if its just a cartridge or two, it
just easier and cheaper to not risk gumming up your print head and
buy fresh cartridges... or print more often :->
Hope this helps.
Howard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Aaron Good"
<agood214@c...> wrote:
> Anyone have any tips on how t best store a partially used cart ?
> Thanks
