Curves printing
2004-12-30 by sinwen
It is said for Schwab's curves using UT-7 : a.. Make all adjustments to your file in grayscale. a.. Convert to RGB file. a.. Apply adjustment curve and print with the following settings:. OK, then a.. Smooth Fine Art Paper Setting Where ? In the driver ? If it is in the driver, what setting sould we type in PS ? Same as source ? In PS ? If it is in PS, do we set again SFA in the driver ? With the Eps4000 , SFA in the driver is impossible using paper tray and I never managed hand feeding, never, no matter how many time I tried different possibilities. Eps4000 driver is a pain really ! Thanks for your suggestions Michel [Non-text portions of this message have been removed]
