I´d like to add more positive results: (I changed thread of this
msg)
I have QTR 2.1.c and gui 2.1.7 and they work.
I regret not documenting what I had to do, because after installing
the new versions I had the famous "QTRAnguish"-situation: nothing
seemed to happen. I worked and wondered with the system about
perhaps an hour before it worked.
I saw that file on finnish "tabletop=työpöytä" cannot still
be read
(just like Ukko told). I have changed mails with Roy about this, but
it is not a big problem when you know it. I have my printable files
in a separate folder, not in any of QTR-folders. QTR is on drive C,
printable files on drive F.
I did not restart my computer (WinXP) but I removed the most obvious
QTR-files before using the new installing program. Sorry but I have
a feeling that this was not everything I had to do, just cannot
remember.
I just write this note to give you folks hope with this great
software, I am sure Roy and Stephen will find something that makes
installing more streamlined.
Cheers, Esa--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy
Harrington" <roy@h...> wrote:
> Yes, things have been going on while I was out too.
> I've been able to isolate two major problems --
> 1) the sheet/roll paper feed problem
> 2) people with multiple drives are likely to have difficulty.
> There are still two known issues that are easily worked around.
> 1) Only the 1440 resolutions should be used. 2880 and 720 are not
> working and wouldn't be useful with the current profiles
anyway.
> 2) There are some foreign character restrictions. Some special
characters
> are a problem in either the filename or the folder pathname.
> Limiting yourself to standard ascii characters will work
around this.
> I've sent the info to Stephen and as soon as we can get the simple
> fixes in and a new download we should all be a lot happier.
> Thanks for your patience.
> Roy
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael
Hung"
> <mhkhung@y...> wrote:
> > Wow.. so much stuff happened over a dinner when I wasn't looking
at
> > the messages..
> > First, to resolve problems.. we need to divide and conquer...
> > The following problems are known.. You are likely to have QTR and
> > QTRgui installed correctly already..
> > 1, Print at 2880 on certain papers on certain printers... The
profiles
> > are done with 1440 anyway, use 1440.. (Even in the Epson driver,
you
> > cannot select 2880 in all papers)
> > 2, Sheet feed vs roll vs manual feed.. The QTR program IS
PRINTING..
> > just certain setting's wrong and the printer's incorrectly
trying to
> > load paper in the wrong slot. Hopefully we will narrow down the
> > settings/problems soon together..
> > If you are not having the above problems.. (For example,
complaining
> > about cannot locate file/directory, etc)
> > - Run Steve's cleanup program
> > - Reinstall as told by Steve.. and
> > - Install to C:\Program Files\QuadToneRIP directory. QTR is tiny
> > anyway, and it likes to be in that directory :).
> > - Print from C drive until we can track down why printing
doesn't work
> > in other drives for some people. You just need to save a copy of
your
> > image to C drive.. Since you are likely making a copy in
> > Photoshop/QImage to 8-bit mode anyway, save it to a temp file in
C
> > drive and print that file..
> > If none of these works, please post the log files (Like the one
that
> > print when renamed).
> > Michael
