Re: [Digital BW] Re: IJC/OPM_windows
2005-01-04 by A. Huntley
Thank you, Antonis. This is exactly the kind of information I was looking for! As I suspected the scanner solution for building profiles is not the best. And, I definitely would not rely on my old eyes! You have given me much to think about...think I'll surf on over to eBay and see what used densitometers are going for. Thanks, again, Alan Huntley
----- Original Message ----- From: "Antonis" <antonisphoto@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, January 03, 2005 5:33 PM Subject: [Digital BW] Re: IJC/OPM_windows Alan, as with any software, the more control it gives you the more learning you have to do. Photoshop Elements is easier than the full version but you also have fewer controls. For those who don't want the extra controls IP is fine. I bought the Mac version when it first came out - about 2 rev numbers ago. i am not familiar with the current product, but I hear people are happy with bw and color just as you mention. I didn't pursue it because I was frustrated with canned profiles, and the choices IP made (back then) in their "recipes" for the grayscales. For example, they would send me a profile that allowed tiny white dots to show in the deep shadows because they cut the "cyan" too soon in trying to get better dmax. Even if I had insisted that they fix it, it would be days before I would get a working profile. Now, if I make that mistake myself, I fix it in under 5 minutes. In my book, its worth the learning curve to use IJC and make your own profiles. The PC version offers a lot of "handholding" that the Mac version didn't have. They both work the same in terms of the underlying "engine", but the PC version will help you better not to get lost if you are new. For example, when it launches, IJC will ask what is it that you want to do - such as start a new profile, tweak an old one or just change the tone - and take you to the appropriate tab in the program. Likewise, it will make it very clear if you save a profile with or without linearization embedded. Also, it gives you good strating profiles or curves so you are not totally starting from scratch.... etc etc. I am hoping that for people who are new to it, the interface adapts to multiple levels of expertise. At the beginning it tries to guide you more, but as you get experienced you can turn off some of the extra dialogs or pop-ups. Maybe you can ask Bowhaus for the manual and decide for yourself if you are up to the task (!). The scanner method of linearizing profiles is better than eyeballing but not as accurate as a densitometer. i haven't done much with the scanner myself. I use an 810 X-Rite - probably not too difficult to find on Ebay these days. When you are saying that you are trying for the "very best" in bw printing, you must also decide if you are ready to learn new software and get whatever equipment it takes. The "very best" won't come from canned profiles, only the "easiest", which you've already done. Keep in mind that for the PC, there is also StudioPrint that allows you to build your own profiles. It doesn't offer the option of the scanner but it works well with the eyeOne and similar spectros. In fact, it also allows for automatic entry of the readings from the instruments it supports. The catch, of course, is that it is several times the cost of IJC/OPM in return for which you also get the benefit of a full RIP (color/bw, postscript option etc). Currently, OPM for the PC does not have an option for Postscript, does not allow image imposition (to gang several separate files in one print job) and does not allow the user to save settings as a job. IJC (for either platform) accepts any set of numbers from either spectro or densitometer, but the 26 numbers have to be typed in manually. As for sepia on the 2200 - i made some "extreme sepia" profiles for a project I was printing last year that looked terrific. With IJC, there is no limit other than that of the inks themselves. A full-color UC set offers more than you'll ever need for toning. So, whether you decide to bathe the whole image in yellow or just tint the highlights using an alpha channel - it's all there for you. I can't tell you how exactly that compares to the current version of IP, just that with IJC you can make your own creative decisions instead of leaving them to someone else, outside the studio. Antonis
