Re: [Digital BW] epson 2200 and MIS UT7
2005-01-15 by Bob Frost
Mike, Correction. The 2200s are made for EPSON pigment inks. If you use those inks, you will not have to do much unclogging (in my experience). But if you use 3rd-party inks, you may still have to do unclogging; just depends on the ink. Bob Frost. ----- Original Message ----- From: "Kelin7" <kelin7@...> 1) Since 2200's are made for pigment inks I assume I'm going to spend a lot less time unclogging them. Is that correct?
